03-19-2011, 07:57 PM | #1 |
Newbie Join Date: Feb 2011 Location: Lockhart, Texas
| Any how-to's for 4-link?
I have a trail honcho and want aluminium 4-link front and rear and also aluminium for the steering links. Kits seem to be way expensive though.
03-19-2011, 08:32 PM | #2 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
This has always been my suggestion....Aluminum rod, 4-40 all thread rod, whatever rod ends you want, a digital or dial caliper, go to the Axial web site, check out the links you want...ie, get the product manual for the aluminum kit upgrade and it'll tell you exactly what length the links are in MM. Go and make them out of your own material. Bam, you've got a 4 link and aluminum steering at a cheaper price. If you feel the need for bling, just polish the aluminum until it shines. Epic.
03-19-2011, 09:11 PM | #3 | |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
03-20-2011, 09:41 AM | #4 |
i just used the plastic axial 4-link truss, and home made 1/4in delrin rod for the upper links
03-20-2011, 10:42 AM | #5 |
Newbie Join Date: Mar 2011 Location: Baltimore
I put the plastic 4-link on last night. I used traxxas P3 112mm Rods. It actually helped out with the angle of the drive-shaft a little.
03-20-2011, 05:26 PM | #6 |
Pebble Pounder Join Date: Aug 2008 Location: marlborough, ct
don't 4-link the front. You will have better traction, and performance with the Y-link or a three link. For rear 4-link axial truss use same length links upper and lower
03-20-2011, 09:16 PM | #7 |
Thanks for the suggestions on materials. What about what the rod ends attach to? Also on a side note why do people want to frame mount their servo? I can't see the advantage, or is it just for scale? |
03-20-2011, 10:04 PM | #8 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
03-21-2011, 09:19 PM | #9 |
Rock Stacker Join Date: Feb 2011 Location: British Columbia
I used the traxxas rod ends, 8-32 threaded rod and 1/4 stainless tubing. The stainless doesn't burr up as much as aluminum does. got the idea from here: http://www.crawlcanada.com/forum/sho...tainless+steel Last edited by seanh; 03-21-2011 at 09:28 PM. Reason: photo |
03-21-2011, 09:36 PM | #10 |
Thanks for the link Sean, that's exactly what I was looking for.
03-21-2011, 10:21 PM | #11 |
No problem. Being a newbie myself, I found that site very useful.
03-28-2011, 09:12 PM | #12 |
Rock Crawler Join Date: Jan 2011 Location: singapore
hi there, i'm thinking of doing up DIY aluminium links too. searched ebay for the rod ends, will these rod ends be suitable? http://cgi.ebay.com/Traxxas-Revo-Rod...item230f7aa60f and also, is the price ok or are there cheaper ones? thanks a lot! |
03-28-2011, 09:23 PM | #13 | |
03-28-2011, 09:30 PM | #14 |
Hard to find 1/4" stainless tube but I finally found some from omnimodels.com Just waiting on some hardware and the tubes to come in. Also ordered some wheel eights. |
03-28-2011, 09:52 PM | #15 |
| are the large revo rod ends suitale for the steering links too? lucky that i asked u guys!
03-28-2011, 10:39 PM | #16 |
Quarry Creeper Join Date: Sep 2010 Location: Gilbert, Az
ok please forgive the newbie & questions but i guess the revo rod ends use the stock axial hardware to bolt up or do you also use the revo hardware in the axial axles at the connection points? i am running a dingo scx10 chassis & would love to do this very thing! but i am also very new to this & am learning... thanks! |
03-29-2011, 04:09 AM | #17 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
tra2742 and 6/32 althread work also if ya dont wanna run the bigger revo ends. The ball is a hair narrower then stock so just use some washers so they dont move side to side. I also installed these on the shock bottoms for alittle more height.
03-29-2011, 04:26 AM | #18 |
I think I will stick to the 5347 large review ends since I have not ordered... but for the threaded rod..... for 8-32, is there a "metric" way of describing? My part of the world uses metric... if not, i'll just wait for the rod ends to come before searching for the threaded rods. Thanks a lot guys |
03-29-2011, 07:26 AM | #19 |
8/32 would be close to 6mm according to the link below, but i think revo ends are 4mm? probably best to get the links 1st http://infinityline.net/conversion.htm Last edited by Cableman; 03-29-2011 at 07:54 AM. |
03-29-2011, 03:07 PM | #20 | |
