03-29-2011, 10:20 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
| caster angle
What is the best caster angle for the front.? I did a cms last might and also changed links around to get my pinion angle better. But in the process my faster is way positive now. I have the clockable hubs in front but it will clock them farther positive. ( positive is upper forward right? ) Second question. I have heard of ppl using the same length links on the 4 linked rear. I tried it last night with the axial 4 link truest but my drive shaft was at a massive angle. Is that right. So instead I used the 106 lower and 98 upper. Until I can order a set of 91.. I just thought it was odd the angle of the drive shaft like that. It didn't seem to bind but still that has to be stressfull on it. |
03-29-2011, 05:38 PM | #2 |
Rock Stacker Join Date: Nov 2009 Location: long island
on my honcho with the axial 4 link i run a 106 mm link with a 4 mm spacer on each end for a total of 116 mm on the lower, and a 106 mm upper, it gives it a good drive shaft angle and the increased length gives it more stability
