05-15-2011, 09:16 PM | #1 |
Newbie Join Date: Mar 2011 Location: Glendale
| First Time Building A Kit!!!
I decided that I want to build my first kit and it was going to be a Honcho! I'm new to this hobby and I just need to know some basics on what kind of motor, esc, and servo to get. I want my honcho to be able to go over some big rocks, go through mud, and everything in between! I want know what are the best tires, everything! so thanks for the help guys in advance !
05-16-2011, 01:37 AM | #2 |
Newbie Join Date: Apr 2011 Location: San Diego
Congrats on the new purchase and welcome to the new hobbie!! As for motor I went with a traxxas Titan motor, castle s2v ecs, and the hitec 645 servo. I'm still currently running the stock tires for now for the little times that I took it out it's worked well. Hopes this help!! And enjoy!!
05-16-2011, 02:47 AM | #3 |
Rock Crawler Join Date: Jan 2011 Location: Okanagan
buy spare allen keys 1.5mm 2.0mm and 2.5mm and both ball point and non ball makes a difference. Also if you plan on mudding or water buy a big tube of grease the kit doesnt come with enough. suggestions on motor, i purchased the 27t axial motor for dirt cheap im very happy with it. I also got a RC4wd 35T motor and love it for crawling! I hear that the Traxxas XL-5 is a good purchase for the price and is waterproof out of the box i hear? i found a novak super rooster for dirt cheap at a pawn shop and i love it. but its pricey to start the hitec 645 is a good start. the receiver and transmitter is up to you and your preference but i run the old axial receiver and transmitter and no problems. watch your servo arm it may come loose, adding thread lock to the screw to hold the arm on works good. driveshafts will probably be the first to go, so expect to have to purchase metal ones later or do it before you break them then you can run the new ones after thats my 2 cents off the top of my head |
05-16-2011, 08:09 AM | #4 |
Newbie Join Date: Feb 2011 Location: Airdrie, AB Canada
Putting the drive shaft together may be the hardest part of the build, well, at least for me when I worked on mine (Step 10 in the Honcho Manual). Putting that metal driveshaft yoke and plastic drive shaft together may take a while, so watch out for that. It may get frustrating at times, but here's a video that I followed that might help: Building The Drive Shafts. After that, most of the build should be a breeze! |
05-16-2011, 03:56 PM | #5 |
I've heard alot about a Tekin motor and esc package together, how is that ?
05-16-2011, 04:57 PM | #6 |
| It works great! Really smooth when crawling at low speed, good drag brake. Mine is the 35T motor so I get good wheel speed as well when I want to get out of trouble like getting stuck and going uphill.
05-16-2011, 05:13 PM | #7 |
also guys, should I upgrade the tire on my honcho or eave them stock I havent really heard anything about them and I really want to try the Mickey Thompson baja claw tires
05-16-2011, 05:37 PM | #8 |
05-16-2011, 06:14 PM | #9 |
Newbie Join Date: Apr 2011 Location: Rabble
I would also stay with the flat irons for a while. You might like them a lot.
05-16-2011, 08:00 PM | #10 |
alright thanks guy, i also want to know about some shocks. I've heard of some people putting bigger shocks in?
05-16-2011, 10:38 PM | #11 |
becareful of doing this or moving the shocks lower, my brother in law broke his driveshafts, and my new driveshafts don't work very well with a bigger shock.
