05-23-2011, 01:08 PM | #1 |
Quarry Creeper Join Date: Feb 2011 Location: Austin
| New Build - Servo / Steering issue
So I am almost finished with my stock build and have run into an issue. The servo post is hitting the frame brace and allowing almost zero flex to that side. See photo. Also, the drag link is hitting the frame rail when flexing the other way which allows very little flexing. This kit is getting frustrating. I know a lot of people customize parts for their axial, but I just want to get a stock setup going before I do anything else. Any suggestions? Thanks Last edited by Slaughter; 05-23-2011 at 01:40 PM. |
05-23-2011, 02:54 PM | #2 | |
05-23-2011, 03:00 PM | #3 |
get out the dremel and grind it down a little, and if its the honcho kit it will probaly hit the frame cross member in front of the servo when you put the arm on the servo, so grind!
05-23-2011, 04:22 PM | #4 |
Rock Crawler Join Date: Jan 2011 Location: Okanagan
mine does the same thing, one way to fix it is move the servo to the chassis, or get bigger shocks... sucks. what my plan for the future is moving the servo to the middle of the chassis, and running a link to the axle that turns a L servo arm that turns the steering links. or waiting till i get a behind the steering kit. and see what i can fiddle with |
05-23-2011, 04:28 PM | #5 |
Thanks guys. I am just trying to troubleshoot as I build so I don't have to tear it down later. Seems like another poor design like my other thread regarding the spur. I will get the RC4WD CMS kit later to fix the issue. In the mean time I guess I will do a little dremeling. |
05-23-2011, 06:59 PM | #6 |
mine did the same ,i just ground a little off the servo mount and it works fine. and like spike said get longer shocks that also helps |
05-24-2011, 05:24 PM | #7 |
Yeah, I was kinda ticked when I realized this assembling my SCX, and having to tear it all back apart, lol. Like everyone else already knew, a few minutes with a Dremel or file will be neccessary on the servo mounts, the crossmember in front of the servo, and lower edge of the crossemember behind the servo. It's not so much that I had to modify it, but the directions should at least warn me ahead of time. For the steering I installed an offset rod end on the servo arm (the same ones as on the tie rod) and removed the spacer between the rod ends on the knuckle. It barely clears on uptravel. |
05-24-2011, 06:23 PM | #8 |
you guys also gotta realize that your scx10 will not have the weight of your hand pushing the shocks down. the scx10 will only have the weight of the scx10 behind it. so what i recommend you do is take your chassis and go play with it, and watch it articulate, and watch the servo move up and down, it doesn't hit as much as we all think it does. but something with the weight of our hands and pushing the shocks to articulate the chassis to make the servo hit is different than actually driving around on rocks. etc... |
