06-03-2011, 08:42 AM | #1 |
Newbie Join Date: Aug 2010 Location: Almeria - Spain
| Podenco Bruto Xtrem :: Evo 3 :: Dingo 2.2
Hi !!!!!! I want to present the latest changes in my Scx10 Wheelbase: 12.20 in - 31 cms. Esc. Tekin FXR Motor Tekin 55T 87/17T Proline Super Swamper TSL/SX 2.2 You can see more pics in: https://picasaweb.google.com/podencojones Now I have a Ni-Mh battery but I want to change to Lipo. I want one that has little weight, this battery would be fine? Zippy 3S 2.200mha. 20C. has little power? Perhaps, be better this one: Zippy 2800mha. 30C I do not know, what would you think that battery right? Greetings !!!!!!!!!!!! |
06-03-2011, 08:53 AM | #2 |
Pebble Pounder Join Date: May 2011 Location: Antwerp Belgium
What voltage is your Ni-Mh battery now? An 3s lipo is 11,1V. An 2s lipo is 7,4V. |
06-03-2011, 09:09 AM | #3 |
06-03-2011, 09:15 AM | #4 |
20C is more then enough for your scaler. I run my axial scx10 honco on 2S lipo's. I have 2400mAh and 4000mAh lipo's. Runtime depends on your driving style and the underground where you drive on. But it probably would be around 1hour and a little bit your 2200mAh. It realy depends. For example: i drive sometimes my 4000mAh empty in 1 hour. But other times i can drive with my 2400mAh for 4 hours. Like i said, it all depends on how you drive, and where you drive. Maybe a better idea, runtime with the 2200mAh lipo will be around the same as with an 2500mAh Ni-Mh battery. Maybe longer now, because of the higher voltage... Edit: does your ESC has lipo-cutoff? You realy need to know when your lipo is empty. If you keep driving with your empty lipo, you may trow your lipo by the thrash. |
06-03-2011, 09:24 AM | #5 |
Ok !!!!! Yes, the esc have lipo-cutoff for 2S and 3S Thanks !!!!!!! |
06-03-2011, 10:12 AM | #6 |
Rock Crawler Join Date: Apr 2010 Location: America
man i like that grill it looks great
06-03-2011, 11:24 PM | #7 |
Quarry Creeper Join Date: Feb 2006 Location: Sacramento
Very original take on the Dingo, very cool. . |
06-04-2011, 12:55 PM | #8 |
Rock Stacker Join Date: Apr 2011 Location: Upper Peninsula, MI
| I am also using 3S 2200mah 20C lipo packs. I just used my EagleTree datalogger to test my SCX10 and I drew a max of 10A, with an average through the run of 1A. So the packs are definitely enough to handle that amount of current. You should get around 2hrs runtime from a full charge, but could be more or less depending on how you drive.
06-05-2011, 02:10 AM | #9 |
Thank you all !!!!! Finally I bought 3S 2.800mha. 30C, I think I'll have more time and strength!! Greetings !!!!!!!!! |
06-05-2011, 08:20 AM | #10 |
Quarry Creeper Join Date: Mar 2006 Location: ft. collins
tough looking rig, looks awsome. Nice stance and origional |
