06-29-2011, 09:45 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: right here!
| Where to get robinson racing bevel and pinion gear
Ive searched anc searched. Can anybody tell me where they got theres. I seem to cant find some. Do they even make one for the axial trans? Even the robinson racing website doesnt have it. |
06-29-2011, 10:06 AM | #2 | |
The transmission gears are here. Clicky me. To my knowledge Robinson doesn't make a bevel gear for the axle. | |
06-29-2011, 03:02 PM | #3 | |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Correct bevel gears are from axial the rest click on the link | |
06-29-2011, 10:42 PM | #4 |
damm they dont make for the axle? thats the one im looking for IF they ever made it. Any substitute for these mine keeps on messing up i went through about 3 integy heavy duty ones.
06-29-2011, 10:52 PM | #5 | |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
there are the stock Axial Bevel gears which is a pot metal and then there are the Hardened steel bevel gears. They are both made by Axial. 3Racing makes a stock gear ring and pinion that is not bad at all. But get the Axial ones. I have a thread in the AX10 threads which is a sticky at the top of the theads that has links to parts for the AX10, most parts transfer to SCX10 | |
06-30-2011, 07:39 AM | #6 |
OK sorry for the confusion im not misunderstanding. What i meant was, I now know that robinson didnt make gears for the axle and only for the trans. My question is that is there any substitute for the "toughness" or as tough as a robinson gear. I went through 3 heavy duty ones made by integy so i figured there should be somethine out there that can handle more abuse than these. I will be tring the heavy duty ones by Axial to see how it holds up. Do any of you guys shim the gear when the axle has been reclocked?
06-30-2011, 09:32 AM | #7 |
Rock Crawler Join Date: Oct 2010 Location: Abbotsford BC
06-30-2011, 09:46 AM | #8 |
What is your setup that eats up the stock gears? Or are you just eating up the Integy gears (which doesn't suprise me)? I've had good luck with stock gears over the years in my rigs. I run the stock gears in the front axle and the low gear set (43/13) in the rear axle of my 2.2 Cobalt Puller powered TTC trucks. http://www.rpphobby.com/product_p/ax30402.htm |
06-30-2011, 10:02 PM | #9 | ||
