07-08-2011, 11:57 AM | #1 |
Quarry Creeper Join Date: Nov 2010 Location: right here!
| truck steers when in reverse and full throttle problem
Ive had this truck for awhile now and its been bothering me. When I go in reverse even slow itll steer in one direction a little and when moving forward AT full throttle itll steer and makes it hard to control. What can be causing this problem? I made sure the bottom end of the shocks and the lower links has no play but still the same results. Anybody encounter this problem before? I also tried switching servo and its still the same.
07-08-2011, 01:48 PM | #2 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Does it turn the same direction in fwd and reverse? Is it the same direction all the time? I take it you have already adjusted the center on your radio. What radio are you using? Measure the wheelbase on both sides to see if anything thing there is out. |
07-08-2011, 03:03 PM | #3 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
Chassis mounted servo without a panhard bar?
07-08-2011, 04:20 PM | #4 | |
Servo is mounted on stock location. | |
