07-14-2011, 08:53 AM | #1 |
| Can TLT Hex Hubs Fit SCX10?
I need a bit more offset on my SCX10 based rig. Will TLT hex hub adapters work? http://rcpcrawlers.com/product.php?p...&cat=17&page=1 Thanks! |
07-14-2011, 10:29 AM | #2 |
Yes they will fit.
07-14-2011, 04:29 PM | #3 |
Built, not bought Join Date: Oct 2004 Location: Gresham
The ones you linked to won't work very well.They're made for the TLT CVD's which are 6mm.I think the hole will be too big on those to work right.
07-14-2011, 05:27 PM | #4 |
You could try these. I been running them on my honcho for while now. They tough. |
07-14-2011, 08:38 PM | #5 |
eric113, too bad those are plastic. I think I'll just order up a set of these Integy aluminum ones....see how long they hold up lol. I just need wider offset in the front. My SCX10 based rig is really a TTC weighing in at around 8-9 lbs RTR 10T puller on 4S. This is what's going on even with a small washer between the wheels and mounting the tie rod underneath the VP Zero Ackermans on clocked C's.... I went ahead and ordered these... http://www3.towerhobbies.com/cgi-bin...&I=LXRTU4&P=FR |
