08-18-2011, 09:03 PM | #1 |
Rock Stacker Join Date: Feb 2011 Location: Dallas
| Dual motor mount....Anyone tried it yet?
Was looking for a new ideler gear for my Honcho when I came across this little item. Its a dual motor mount. I was wondering if anyone has tried it yet and if so how did it work out and how did you wire it up. Take a look. http://www.rpphobby.com/product_p/levscx-03.htm |
08-18-2011, 11:42 PM | #2 |
So I guess nobody has tried it. Do you think its possible to Y the power and negative wires and run matching motors on one ESC or would it overload it? Or would it be more for running a slow motor and ESC for crawling and a faster combination for bashing without having to change them out?
08-18-2011, 11:49 PM | #3 |
Quarry Creeper Join Date: Jul 2011 Location: Lake City, Fl
you'll more than likely fry the ECS you need two ECS's; one for each motor; and a receiver capable of using two ECS's the dude at RC Sparks put one in his monster dually he built (or is currently building I should say) http://www.youtube.com/watch?v=JnoVgXV0oU4 if the money is there in the future, I may throw one in the Tacoma I'm building now, just because, and then put a SMALL spur on it and some larger pinions, since TWO motors will basically double the torque, and since there's already enough to slip the slipper clutch, I don't see what use MORE torque would be... but more SPEED is always nice Last edited by iamsuperbleeder; 08-18-2011 at 11:52 PM. |
08-19-2011, 02:26 AM | #4 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
I've never run one of a SCX but i have driven an original dual brushed E-Revo and you definitely notice the extra torque that 2 motors give you. You don't NEED two ESC's. You can run two matching motors off a single esc. Just make sure you dont overload it by exceeding the turn limit. The way i was taught to roughly work out what sort of load a ESC would see is to divide the turn rating of the motors by the number of motors and that roughly gives you the equivalent turn rating for a single motor. For example, running 2x 55t in parallel the ESC would see a similar load to one 27t. 2x45t = 22.5t load etc. Hope it helps mate. |
08-19-2011, 10:13 AM | #5 |
Rock Stacker Join Date: Sep 2010 Location: Medway
I'm suprised nobody mentioned using a EVX-2, which is made for dual motors. The only issue I can see with this is have to run dual batteries as well and 2 6 cell nimhs would be pretty heavy
08-19-2011, 11:00 AM | #6 |
Rock Stacker Join Date: Jan 2011 Location: brooksville
Or u also can get a Novak crawler roster and run 2 35t-55t. Iv been lookin to do that and see what it does
08-19-2011, 11:48 AM | #7 |
Pebble Pounder Join Date: Aug 2008 Location: Living in Paradise
08-19-2011, 01:38 PM | #8 |
I guess I don't really understand why? It's not like the SCX is such a big heavy truck that you need two motors to run it. From the looks of it, you're adding quite a bit of weight up high with that second motor. Not really sure what this solves other than it can be done. Anyone else know anything about this? |
08-19-2011, 03:49 PM | #9 |
My truck is already heavy carrying a 7.2 and an 8.4 nimh batteries so I don't see what it will hurt. Be kinda cool if there was a way to engage one two get you going or crawling then the other pick up for speed and bashing
08-19-2011, 07:02 PM | #10 | |
Quarry Creeper Join Date: Oct 2010 Location: Grandview, IA
Overall I see no point in two motors. An appropriate motor hasno troubles moving the Scx however you need it too. | |
