08-31-2011, 10:32 PM | #1 |
Newbie Join Date: Aug 2011 Location: calgary
| spur gear help pleasee
im running the stock motor/spur gear on my honcho, was wondering if theres a differnt sized spur gear i can slap on for more torque?? it seems as if its kinda unstable at low speed as it jerks forward right now
09-01-2011, 12:23 AM | #2 | |
Quarry Creeper Join Date: Jul 2011 Location: Lake City, Fl
a smaller spur (or larger pinion) will give higher top speeds and less torque the stock spur on the Honcho is an 87 tooth. the higher the number of teeth, the larger the gear. BUT, there's a limit on how large of a gear you can install before the gear comes into contact with the drive shaft, although I am uncertain what that limit is in my personally opinion, it's much easier, and just as effective to just change to a smaller pinion on the motor. the stock is a 20 tooth, which is pretty large. you could step down to a 14 or 12 tooth and probably notice a good difference I'm still running the stock gears on mine because I do like the extra speed, but I may end up gearing down for more torque since a nice side effect is that it extends your battery life since there's less stress on the motor CKRC sells some spur/pinion kits. this is actually the one that I will more than likely go with http://www.ckrccrawlers.com/ckrcs-32...ng-p-3316.html | |
09-01-2011, 02:42 AM | #3 |
Quarry Creeper Join Date: Aug 2011 Location: United Kingdom
Both RTR and kit have the 87T spur, however the kit comes with a 14T pinion while the RTR comes with a 20T.....just depends what you have currently. If you already have the kit with the 14T pinion you would then need to look at your motor (go for a higher wind)....or possibly use a slightly larger spur, say 90T and up |
09-01-2011, 03:29 AM | #4 |
RCC Addict Join Date: Jul 2011 Location: Orlando
If you plan on running MIP driveshafts, 87t spur is as big as you will be able to go. Its already super close to touching. Any larger and its a definate hit. Go smaller on spur and get sometihg like a 35t motor. It will give you more torque and you wont lose all your wheel speed. Good luck.
09-01-2011, 04:55 AM | #5 |
Rock Crawler Join Date: Jul 2011 Location: Incirlik AB, Turkey
awesome info answered some questions I had |
09-01-2011, 06:32 AM | #6 |
Pebble Pounder Join Date: Aug 2011 Location: Twin Cities
I have the kit Honcho with a 45t motor...AWESOME crawler that goes about the speed of a brisk walk, maybe. When crawling, it will stop whenever I release the throttle...no matter the angle. I also have a used Dingo RTR with the 27t motor (different gearing as mentioned) and the thing is FAST and not a good crawler. It currently has 2.2s on it (going back to stock soon) and even with drag brake at 100%, it rolls down obstacles when the throttle is released. After 1.9s are back on, I will probably look for similar motor and pinion I have on my Honcho...SO much more fun for me. |
09-01-2011, 07:02 AM | #7 |
just get a higher turn motor if you want more torque
09-01-2011, 03:18 PM | #8 | |
I have a dingo TR comin so yer sayin to change the motor not just the spur gear or pinion gear? Quote:
09-01-2011, 05:30 PM | #9 |
Just change the motor to a larger T like a 35t or a 45t and you should be fine for the style you are looking for. Good luck.
09-01-2011, 06:14 PM | #10 |
Is it as simple as changin the motor or ya need the ESC as well. What's a good intermediate motor brand?
09-02-2011, 01:56 AM | #11 |
I think the AE2 esc should handle a higher turn motor just fine.....
09-02-2011, 08:31 AM | #12 |
Quarry Creeper Join Date: Oct 2010 Location: Grandview, IA
Holmes Hobbies has bothintermediate and comp motors. One of their machine wound 45t's is reasonably priced and right up your alley. Then when you wanna go big you can just swap in the internals to make it a hand wound bad ass ;)
09-02-2011, 05:06 PM | #13 |
Thanks federally
09-02-2011, 06:23 PM | #14 | |
Rock Stacker Join Date: Aug 2011 Location: Come and take it
