Thread: Scx10 upgrades
Old 09-06-2011, 03:41 PM   #1
Default Scx10 upgrades
Hey guys what should I upgrade first steering servo and a few other things or esc/motor? If I do esc/motor I'm gonna do the HH torque master BR-XL and the rc4wd 35t motor and whats a good steering servo? As you can see if I do esc/motor it will be around $120 dollars so a steering servo and other stuff that adds up to that would be nice. And what's other good upgrades that I can put with the steering servo? Thanks
Cypher is offline   Reply With Quote
Old 09-06-2011, 03:53 PM   #2
A quality servo is a much needed feature. Also, get a CCBEC to boost the power of the servo. Get the motor and ESC later. It doesnt matter how much power you have if you can't point it in the right direction.
Wes
brazwewn is offline   Reply With Quote
Old 09-06-2011, 04:25 PM   #3
^^^ is right about steering cababilities but if you get the BR-XL you dont need the CC BEC, the internal BEC in the HH BR-XL is very good and is programmed at 5amp 6volt. Good enough for 75% of the High torque steering servos out there.
Good luck with which ever mods you decide to do.
AsILayDying is offline   Reply With Quote
Old 09-06-2011, 06:22 PM   #4
ya i agree upgrade the esc/motor.. for the steering servo im running an hitec hs-645mg and it gets the job done, but eventually i want to upgrade to the 7950mg because i've seen one work and they are amazing.
AX10wannabe is offline   Reply With Quote
