09-19-2011, 08:47 PM | #1 |
Newbie Join Date: Aug 2011 Location: calgary
| nother question!
my truck was glitching a while ago, people told me to check my on/off switch, it turned out to be the problem with the electronics...i think...but it still is not smooth at ALL while trying to crawl slow...could this be a motor problem?? it work perfect top speed but the exact opposite slow help please
09-19-2011, 09:37 PM | #2 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
Need more info. Is it a kit? 2.4 or AM? What ESC? What battery type? Stock gearing and tires?
09-19-2011, 10:38 PM | #3 |
it is a rtr honcho, stock gearing im not sure what the electronics are..it is all in baloons right now but the radio says ax-1 on it if that helps, 1.9 tsl boggers 3000mah batterys, the tires are weighted not sure how much, i have led coils wrapped 4 times around front and twice on back tires, but has ran fine before on them
09-19-2011, 11:07 PM | #4 |
Quarry Creeper Join Date: Jul 2011 Location: Lake City, Fl
the older AE-1 ESC was glitchy at best... but I wouldn't jump right to it being the ESC are you still running the stock motor too? it is possible it's got a bad spot in the motor where the brushes run on it. you can get some decent higher turn motors from RC4WD to put in it for dirt cheap and that would tell you if it's the motor if it's not the motor and you still suspect the ESC, you can probably source a newer AE-2 ESC take off for fairly cheap |
09-19-2011, 11:22 PM | #5 |
Newbie Join Date: Apr 2011 Location: Los Angeles
raido and transmitter need to be re calibrated!
09-19-2011, 11:34 PM | #6 |
Rock Crawler Join Date: Jul 2011 Location: Incirlik AB, Turkey
if it's the old readio 27mhz then there's yer problem
09-20-2011, 05:08 AM | #7 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
09-20-2011, 03:46 PM | #8 |
how do i re calibrate it?
09-20-2011, 05:13 PM | #9 |
09-20-2011, 06:15 PM | #10 |
19 and its irrelevant to my question
