09-23-2011, 10:23 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: trinity
| scx honcho kit vs rtr
hey guy's which is better the and what would be the better bang for the buck the rtr honcho or the kit version which wwould i save money getting the rtr and upgradeing the stuff on it aafter i figured out what i wnated ot upgrade or shoudl i get the kit and put my own stuff onto it i did well a buddy built a tundra kit for me and i woudl up really expensive with that cause i had nothing and am basically starting again here with a honcho id have to add a esc and motor and servo all that stuff thank's zach.
09-23-2011, 10:48 PM | #2 |
Rock Crawler Join Date: Aug 2011 Location: tri cities
Honestly there is no real better option. Unless you already have electronics its gonna cost you more right off the bat. The rtr is $300 give or take and for the alum links its another $50. The kit is $235 with the links but then you need atleast a $30 servo, $50 transmitter and reciever and $100+ for a motor and esc combo. Yes the servo will be alittle better. The controller will prolly be the same and the motor/esc combo will be better. $415 would be your total on the kit. It can save you money if you have no use for the motor, esc, remote, reviever and servo from the rtr. But for me I can always use the spare parts for other projects or for simple back ups. So if you wanna plug and play got rtr. If you have $415 and want alittle better setup then got with the kit |
09-23-2011, 10:58 PM | #3 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
If your bucks up???? Buy the kit, add links as needed for the desired lengths. Buy the best servo you can afford, that way you wont be buying a second servo. Get a holmes hobbys water proof speed control with whatever motor ( from them) you feel is ideal (contact them). Build it your way! Build it overkill that way you wont have to duplicate money!
09-23-2011, 11:54 PM | #4 |
RCC Addict Join Date: Jul 2011 Location: Orlando
Well you can always shop around. I was able to get a Honcho RTR New for 265 since tower was running a deal at the time and had 25 dollars off anything over 200. My LHS had it for 290 and honored the tower deal. The RTR is a very good base, links are super easy and SUPER CHEAP to make. Dont waste 50+ dollars when I can make 2 sets for less then 20 and thats counting the Revo Rod ends costing 7 dollars for each pack (x2) The new ESC is a quality unit, has drag brake, can be programmed (to a point.....its a Castle ESC) it has LiPo cutoff already factory programmed and works extremely well with 2s batteries. I recieved an AX-2 2.4ghz Radio with my Honcho but was surprised and recieved the new AX-3 Radio system with my Dingo RTR, which is actually one of the better out of the box controllers for an RTR. No complaints on either if my RTR's plus now that one of the rigs is upgraded electronics and parts (ESC, motor, reciever....etc.) it gives me a reason to find a roller or try and find a deal on a kit. Since I have the extra parts I might as well get another rig to put them in.... Good luck, either way you will be happy. |
09-24-2011, 09:38 AM | #5 | |
09-24-2011, 02:13 PM | #6 | |
Quarry Creeper Join Date: Aug 2011 Location: Troy
Went way overboard on everything (servo, esc, motor, batteries, etc) up front, so I know that those wont be the thing that breaks. I just took my kit out for the first time today actually wheeling it, and man was I amazed, this thing goes anywhere! | |
09-24-2011, 06:00 PM | #7 |
Pebble Pounder Join Date: Jul 2011 Location: CANADA
well i JUST got home from the lhs maybe 30 mins ago. and im starring at my kit right now. pretty satisfied with it. the rtr just seemed like a bit of a waste. if i bought the rtr i would just end up buying servo esc and motor all over agina. why buy it twice? just my .02
09-25-2011, 11:06 AM | #8 | |
A Quote:
09-25-2011, 12:11 PM | #9 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
I bought the kit cause then I know it's built right. Also it comes with metal links and a clear body. Who wants a green honcho? Puke! Plus of I bought the RTR I'd have to waste my time ripping it all apart to pack it with marine grease and I'd have to buy a clear body because again green is ugly.
09-25-2011, 12:15 PM | #10 | |
09-25-2011, 12:20 PM | #11 |
Everything you stated was easily fixed. Green body... paint it. Upgraded Links cost me 8 dollars for a full set of Uppers and Lowers And saying that its not built right is kindof a joke being that I could crawl with it very well right out of the box. I bought the RTR so I (I say I because its my choice just like its your choice to buy a kit) would have extra parts after I figure out what works and what doesnt. This was my first scaler and I wanted to learn about how they work before I learned how to put them together (some people do it differently) But the great thing about opinions is everyone has them but yours is the only one thats important. But seriously these rigs are built well right out the box. Yes the kit comes with links upgraded (easily made for cheap) yes the servo could use upgrading but works fine for trail running and mild crawling (works for the time being) ESC (AE-2) is a very good ESC, its programmable, has drag brake and can run 2s with LVC built in ( i have run 3s with no issues) A lot of the newer RTR's are coming with the AX-3 like the Wraith so its a fairly nice stock 2.4 radio. Again, it was your choice but just because you bought a kit does not mean that it will be built right. built right is all relative to who thinks what right is. 10 people building the same kit will build 10 diiferent rigs. But good luck with your kit. Lets see some pics of the new rig in build process...... |
09-25-2011, 12:34 PM | #12 | |
Beauty is in the eye of the beholder | |
09-25-2011, 05:01 PM | #13 |
yup thanks' guy's think ill jsut grab a tr when i do get one.
09-25-2011, 05:13 PM | #14 |
In all reallity if you dont like the gear it comes with just throw it on the classifieds for sale and get some money back for the purchase you want to make.... Just my 2 cents |
09-27-2011, 02:17 AM | #15 |
great sound adice got a question my lhs ahs the dingo for like 30 less doe's the dingo coem iwht longer links in the kit to make it logner wheelbase and what obut relocatin the battery mount up fornt liek the honcho thanks' zman.
09-27-2011, 03:40 AM | #16 |
Dingo kit only has the Dingo length links but you will be swapping out for aluminum made links anyways. Just make your own. Its really easy and cheap and this way you can make the lengths whatever you want. See if your LHS will match TowerHobbies, right now 25 dollars off over 200. Good luck.
09-27-2011, 04:54 AM | #17 |
okay cool well it's 289 at lhs right now ill see if he will match it thank's and what obut battery mount can i simple jsut repostion hte cross member's and make it work thank's zach.
09-27-2011, 01:49 PM | #18 |
Rock Stacker Join Date: Sep 2011 Location: Norway
| Dingo is great TR
I recently bought a trial ready Dingo, and this was a pleasant surprise. Only missing threadlock on the driveshaft screws. She runs smoothly and climbs rocks like a goat. I'll be getting a second one when I have beaten the shit out of my Tamiya |
