09-24-2011, 02:09 PM | #1 |
Newbie Join Date: Aug 2011 Location: Canada
| ticking sound
Hey, i took the honcho(rtr) out in the back yard and when i got out to my spot i heard a ticking sound, It didnt do it yesterday. I am going to pull one drive shaft at time and see if that is it. If anyone has had to deal with this befor or knows about any info would be awesome. Ill keep you posted.
09-24-2011, 02:17 PM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: Bay City
Check your spur gear first before ya go tearing anything apart! make sure theres not something stuck between the teeth.
09-24-2011, 02:26 PM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
Probably just a grain of sand in the spur....
09-24-2011, 02:26 PM | #4 | |
took the end of a knife and cleaned it out no more ticking. Now I feel dumb for not checking that haha. | |
09-24-2011, 03:02 PM | #5 |
Rock Crawler Join Date: May 2011 Location: at your moms
my guess would have been the spur gear as well, we run in some sandy areas and often hear the ticking as well
09-24-2011, 03:22 PM | #6 |
Quarry Creeper Join Date: Aug 2011 Location: Troy
while your messing with the gears, make sure you threadlock your pinion set screw. I was running a 5s earlier and popped the setscrew loose. Good thing I didnt lose it!
09-24-2011, 03:27 PM | #7 |
Quarry Creeper Join Date: Feb 2006 Location: Angier N.C.
Another thing I would have looked for was the set screw on the pinion hitting the spur. If you run a small pinion in say the 12 to 14 tooth range. It's easy to miss. Easy to locate too. Just check the spur and see if there are any frayed teeth. Know it was not the problem here, but just something to think about.
09-24-2011, 04:30 PM | #8 | ||
09-24-2011, 09:17 PM | #9 |
Na, just saying that if you run a smaller pinion gear, the possibility of any remaining part of the set screw left sticking out of the pinion could hit the spur while it makes it's rotations. Doesn't have to be loose. Just sticking out enough and the spur and pinion are close enough that it could hit. It would not be a constant hit, just every time the part of the pinion with the set screw in it rotates around to the spur.
09-24-2011, 09:49 PM | #10 | |
09-25-2011, 05:33 AM | #11 |
Newbie Join Date: Jul 2011 Location: paignton,devon,uk
I had a problem with the stock servo ticking and making a right old noise in the rtr kit |
