11-20-2011, 11:20 AM | #1 |
Newbie Join Date: Nov 2011 Location: Salem
| Got my first scx10, couple questions
I just picked up a scx10 for 100$. It has a novak 55t motor, novak rooster crawler, traxxis 3 chan receiver, hr internal shocks, rc4wd rims, hand brothers steering, xspede drive shafts, wireless winch, alumi links, and baja claws tires. It seems like its pretty good, but I just have a few questions. First when im driving it seems like it bucks like something is bent like the spur gear or something. Is this normal? The tire foam seems kinda soft could that cause anything? Also im getting torque twist, I read something about mirroring the tranny? How do I go about doing that? it seems like I also have a little bump steer? I also read 4 linking the rear would help. Let me kno if you have any suggestions. |
11-20-2011, 11:26 AM | #2 |
Quarry Creeper Join Date: Jul 2011 Location: Lake City, Fl
looks and sounds like you got a really good deal! as for the bucking your describing, do you know if the original owner ever tore the trans apart and replace the plastic final drive gear in it for an aftermarket metal one, like a Robinson Racing one? if it's not centered when the outputs are screw tight to it, it'll do that. I don't think the spur will do it, but I know that final gear in the transmission will to mirror your trans, just remove the 4 screws on either side of the chassis that hold the center skid plate and trans mount, pull that plate out and turn it 180 degrees, and then reinstall it. it'll take the majority of the torque twist away it's strange you're getting bump steer with the Hand Brother's servo mount setup; I've always heard that the 3 link and panhard bar setup they use works pretty good at eliminating the bump steer Last edited by iamsuperbleeder; 11-20-2011 at 11:32 AM. |
11-20-2011, 11:29 AM | #3 |
Sorry if pics seem big im on my phone and its hard to resize them
11-20-2011, 11:34 AM | #4 | |
11-20-2011, 11:39 AM | #5 | |
For the hand bro's steering, can I run 4 link in the rear or should I stick with 3 link? | |
11-20-2011, 11:49 AM | #6 |
Its act as if something was out of balanced or warped, I thought to mirror the tranny, the motor should be facing forwards on the right side, so id have to flip the tranny. So just spinning the skid plate does the same thing ?
11-20-2011, 01:15 PM | #7 |
I just checked the trans he replaced it with a metal gear, how should I go about fixing it?
11-20-2011, 01:32 PM | #8 | ||
to fix it, just loosen up the three screws, center it the best you can (I just eyeballed mine) and tighten the screws back down. I also like to use a little blue lock-tite there, just for peace of mind Last edited by iamsuperbleeder; 11-20-2011 at 01:34 PM. | ||
11-20-2011, 01:36 PM | #9 |
Quarry Creeper Join Date: Dec 2010 Location: Lodi
You got an awesome deal on that rig man! As far as the "bucking" is concerned, I would suggest checking the drive shafts and make sure that they are aligned properly. When I first installed my MIP shafts I had a similar issue because my shafts were not aligned properly. To mirror the tranny, just turn the whole skidplate 180 degrees and switch the wires on your motor to reverse the direction. That should work just fine. I'm not familiar with the bump steer issue because I still run my servo on the axle. Good luck and let us know if you get it fixed. BTW... your rig is almost identical to mine |
11-20-2011, 01:40 PM | #10 |
11-20-2011, 03:05 PM | #11 |
Heres a video idk how good you'll able to see it bucking but its kinda bad http://static.photobucket.com/player...120_164805.mp4 |
11-20-2011, 05:15 PM | #12 |
if you're going to mirror the tranny (doesn't help IMO) do it right and turn the endbell on the motor, not swap the wires like stated above. proper shocks, 4-link rear suspension, and weighted wheels will solve your tourqe twist. |
11-20-2011, 05:21 PM | #13 |
I wouldn't do either; just reverse the throttle on the transmitter |
11-20-2011, 05:50 PM | #14 |
Ok well I fixed my torque twist problem a little bit, but that bucking is still really there and its really bad at a slow crawl
11-20-2011, 06:04 PM | #15 |
Rock Stacker Join Date: Oct 2011 Location: Spokaloo
11-20-2011, 06:14 PM | #16 |
Quarry Creeper Join Date: Mar 2010 Location: murrieta
If you do it right it will look like this, the motor is now in the front and the spur faces the back. This took out all of my twist |
11-20-2011, 06:23 PM | #17 |
Rock Crawler Join Date: Sep 2004 Location: eureka
the bucking looks like what happens when the driveshaft u-joints are maxed out. any pics of the driveshafts and the angles their running at ?
11-20-2011, 06:23 PM | #18 |
oh I see what you're getting at |
11-20-2011, 06:26 PM | #19 |
11-20-2011, 07:39 PM | #20 |
I can take a pic of them in a few, how do I correct the the angle?
