01-06-2012, 04:11 AM | #1 |
Newbie Join Date: Aug 2011 Location: Martinsburg, WV
| Axial SCX10 Kick Up Axle Mod
Deleted !!!
01-06-2012, 04:29 AM | #2 |
Quarry Creeper Join Date: Jun 2009 Location: Oslo, Norway
| Re: Axial SCX10 Kick Up Axle Mod
But your truck will loose some steering...
01-06-2012, 02:25 PM | #3 |
No steering will be lost I run it on both my truck Ill have a video up this weekend showing the steering and the truck running with the mod.
01-06-2012, 02:56 PM | #4 |
If you do this mod to the steering axle you could loose steering effectivness. Depends on how much length you add to your top link. Won't effect the rear axle cause it doesn't steer in this case. Lengthing the top links will straighten out the driveline up front but your steering knuckles will be "turning into the ground" (negative caster), thus loosing some steering effectivness. The knuckle arms need to be parallel to the ground or kicked back (positive caster) some. Of course, all things are relative. If your steering into the ground a bit and you don't mind it than your good to go! |
01-06-2012, 03:31 PM | #5 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
Your mod will only help the angle at the axle pinion, not the transmission output angle. Like others have said, I wouldn't recommend it on the front. It's not going to decrease wear and tear on the driveshafts enough to justify the time. Where it will help is the rear axle's approach over obstacles. It will lessen hang-ups on the pinion part of the axle housing. Most will agree the better mod would have been to install a four link and CMS while you had those 3-links off. At least you are thinking of, and trying modifications to your rig. |
01-06-2012, 03:44 PM | #6 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
Crappy mod. It's only good with afternarket chubs so you can fix your steering angle which you destroyed in your mod. Junk.
01-06-2012, 04:02 PM | #7 |
SkinInc69 you don't know what the hell your talking if you don't like it good for you.
01-06-2012, 04:33 PM | #8 |
RCC Addict Join Date: May 2010 Location: Midwest
| Re: Axial SCX10 Kick Up Axle Mod |
01-06-2012, 08:49 PM | #9 |
Rock Crawler Join Date: May 2005 Location: Fort Wayne
What was the mod? I'm interested, heck always interested in new mods to the SCX
Axial SCX10 Kick Up Axle Mod - Similar Threads | ||||
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits | LetsHandleit | Axles, Trannys, T-case | 41 | 06-24-2012 06:57 PM |
Will Axial AX30563 fit on a SCX10 axle? | mtnhrdgr2 | Axial SCX-10 | 2 | 01-29-2011 03:02 PM |
