01-17-2012, 06:21 PM | #1 |
Newbie Join Date: Jan 2012 Location: Presidente Prudente
| MRC axles in the SCX10?
Hello felows! Someone try to put the MRC axles in the SCX10? Regards |
01-17-2012, 06:26 PM | #2 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
| Re: MRC axles in the SCX10?
iv not but im sure it can be done with a little fabrication! give it a try and post pics on how you did it for others that want to try it! Be the first! (to post it atleast) I assume you have tried searching for it?
01-17-2012, 07:38 PM | #3 |
Rock Stacker Join Date: Nov 2011 Location: NEPA
I have an SCX here, and an MRC Pro on the shelf. I'm sure it's possible, but the MRC axles are quite a bit more narrow than the stock SCX axle. Enough so that it may look a bit odd on the truck, unless you are building some other type of scale contraption.
01-17-2012, 07:53 PM | #4 |
Rock Crawler Join Date: Jan 2007 Location: Lehigh Valley
Yes it is possible, a guy I compete with has a class 1 with MRC axles/trans and a SCX chassis. He narrowed the chassis, cut it shorter, but the truck works and looks great. It all depends how much work you want to put into it
