01-21-2012, 08:42 AM | #1 |
Pebble Pounder Join Date: Oct 2011 Location: Wichita
| steering?
Only been running my scx10 Dingo "builders kit" for a few minutes and I don't feel like the steering is up to snuff. I have a Futaba BLS351 servo in it and that should be more than enough servo but I want it to turn sharper. HELP!!!
01-21-2012, 08:50 AM | #2 |
Newbie Join Date: Jan 2012 Location: martinsburg
| Re: steering?
Sounds like you might have a bind issue check your screws going into the C Hub Carrier's
01-21-2012, 11:53 AM | #3 |
Newbie Join Date: Dec 2011 Location: Hampton GA
| Re: steering?
You need a longer servo horn.
01-21-2012, 02:22 PM | #4 |
Quarry Creeper Join Date: May 2008 Location: Colorado Springs
| Re: steering?
Do you get full lock on the knuckles? If so, not much more you can do, don't forget the Dingo has locked diffs, so turning radius isnt the best.
01-21-2012, 04:37 PM | #5 |
| Re: steering? |
01-21-2012, 04:41 PM | #6 |
| Re: steering? I didn't forget, just didn't realize that would have such an impact on turning. Kind of new to this part of the hobby. Thanks for the input, I have a lot to learn when it comes to the crawling aspect of this hobby.
steering? - Similar Threads | ||||
inside tyre touches steering knuckle / steering linkage | murky123 | Axial SCX-10 | 4 | 10-06-2010 04:46 PM |
Getting more steering from the Bully axles after Modding for more steering | jcboof | RC4WD Bully | 15 | 01-31-2010 10:01 PM |
Hot Racing Steering knuckles - more steering than the original plastic ones? | Tomy | Axial AX-10 Scorpion | 1 | 11-16-2008 11:26 AM |
steering fix for stock steering | Got Rocks? | General Crawlers | 1 | 11-22-2005 10:42 AM |
