01-28-2012, 08:09 AM | #1 |
Newbie Join Date: Jan 2012 Location: EVANS CITY
| Broken SCX-10
Hello all I was helping my son "waterproof" he's Axial SCX10. We took apart the receiver box and sprayed the radio receiver with spray on plastic dip.We tried to be careful and not touch the board to discharge static electricity. We also sprayed the front servo as well, we didnt take anything apart on servo just spray the outside with plastic dip. We put the truck back together and the radio is not working. We tried to resync the radio and receiver but its not working. Currently the radio has strong grenn light, we did replace with it fresh batteries. The esc has a constant flashing red light as soon as you turn on truck. Is there any other troubleshoot tips anyone can provide ? If the receiver is damaged can you replace with another brand without buying a new remote ? Thanks in advance Derek |
01-28-2012, 08:35 AM | #2 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
| Re: Broken SCX-10
StArt with checking the plugs going to the receiver make sure the servo and esc are in the correct spots On the recciver I would of used a balloon to waterproof it instead of that plastic stuff just close the end of the balloon with zipties nice and tight Also turn your radio on and then the esc wait a few seconds befor pulling the trigger or moving the wheels let the radio link to the recover and esc first |
01-28-2012, 10:02 AM | #3 | |
| Re: Broken SCX-10 Quote:
I double checked the plugs and everything looks good. We never unplugged the servo, esc or radio receiver. I just covered the truck in paper towels and sprayed plastic dip. The esc still flashes red and doesn't respond to remote. | |
01-28-2012, 10:55 AM | #4 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Broken SCX-10
Try this out. I had issues with my stock radio and receiver acting up lately. Everything was working fine then the radio mysteriously wouldn't bind to the receiver the next day. All my connections were good and I was getting the correct lights blinking. Took apart the RADIO and found a microchip inside that was just barely disconnected. Since its not a soldered on part, it probably came loose from banging/dropping the radio. I would just verify this to rule radio out if you've already confirmed everything else is good. |
01-28-2012, 01:17 PM | #5 |
Quarry Creeper Join Date: Aug 2011 Location: Troy
| Re: Broken SCX-10
Save the headache and pick up a Flysky GT3B. 35 bucks and its a solid radio. Extra receivers are 7...not a big deal if one gets wet and dies (not only that but its super small and pretty water resistant already)
01-28-2012, 01:44 PM | #6 |
| Re: Broken SCX-10 |
01-28-2012, 01:44 PM | #7 | |
01-28-2012, 02:10 PM | #8 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
| Re: Broken SCX-10 |
01-29-2012, 11:21 AM | #9 |
| Re: Broken SCX-10 Who sells it for only $35? That's a good deal! I only see it for $55 :(
01-29-2012, 11:56 AM | #10 |
Rock Crawler Join Date: Aug 2008 Location: Bristol Va.
| Re: Broken SCX-10 |
Broken SCX-10 - Similar Threads | ||||
Convert a SCX-kit or SCX-TR into Honcho w/ part #s | neoakaj | Axial SCX-10 | 0 | 12-23-2009 09:32 PM |
