01-28-2012, 04:28 PM | #1 |
Newbie Join Date: May 2011 Location: Uk coventry
| scx10 dig and motor problem
hi all hope you can ive added a vp dig unit to honcho and mirrored ish the motor so dig is on back the problem ive got is that is faster in reverse an front ive changed settings with no luck i think its gearing is the problem |
01-28-2012, 05:20 PM | #2 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: scx10 dig and motor problem
The problem may be that your motor has advanced timing in the normal direction of rotation, and since you've reversed it to the other side of the trans you now have to run the motor in reverse to go forward. If it's a sealed can (non-adjustable) type motor there's not much you can do. If you have one that is adjustable, set the timing to zero degrees for equal speed forward and reverse.
01-29-2012, 05:35 AM | #3 |
Thanks for the reply mate I don't think I've for time timing adjustment its a hobbywing esc and a ezrun 10.5t motor radio gear is spectrum dx3e all sensored esc and motor I've bought this dig and looks like I'm not going to be able to use it
01-29-2012, 11:45 AM | #4 |
Another thing you could try is to check the throttle trim on the radio. Make sure it's set to zero (neutral) and then reprogram the esc. Hope you can get it straightened out .
01-29-2012, 03:24 PM | #5 |
| Re: scx10 dig and motor problem Tried that mate not good think ill will be running my honcho without a dig unit and I've seen them on there but they have used brushed motors could that be the problem ?
01-29-2012, 04:18 PM | #6 |
I looked up your motor and it has fixed timing (advanced in the normal rotation). If your ESC does brushed motors, you could always go that route. There are many to choose from and most are not too pricey.
01-29-2012, 05:12 PM | #7 |
| Re: scx10 dig and motor problem Thanks for the info mate what sort of motor would I need and how would I advance the timing sorry for the questions bit of noob when comes to motors and escs thanks slap
01-29-2012, 06:13 PM | #8 |
I run brushed 35 turn motors on 3 cell lipos. Great low end torque and control with a decent top speed. Your motor is equal to a 23 turn brushed motor, so anything 21-35 turns should be fine. The timing can be adjusted by loosening two screws on the endbell and turning it slightly one way or the other. If it has adjustable timing, there will be a mark or pointer on the endbell and multiple lines on the can. The center line will be zero degrees. Turning the endbell in the direction of rotation will advance the timing, the oposite way will retard it.
01-30-2012, 06:15 AM | #9 | |
| Re: scx10 dig and motor problem Quote:
scx10 dig and motor problem - Similar Threads | ||||
r2 dig trans with dig unit scx10 | 1320king | 1.9 Scale Rigs | 3 | 01-03-2012 01:54 AM |
question about motor stutter problem with axial scx10 | txcountryboy85 | Newbie General | 1 | 08-14-2011 09:34 AM |
Help with dig problem? | 5150bronco | Axial AX-10 Scorpion | 8 | 04-20-2010 10:48 PM |
vp dig problem | SUPERCLODBUS | Axial AX-10 Scorpion | 4 | 07-18-2009 01:52 AM |
