01-31-2012, 04:50 PM | #1 |
Rock Crawler Join Date: Jul 2011 Location: Incirlik AB, Turkey
| Best way to take slop outta chubs
I have alot of slop in the steering at the knuckle. Do I just throw a screw in with a bigger head? Are there specific screws for the knuckle? I didn't think it would bother me but the tires are gettin warped from when I turn the castor gets off and they lean.
02-01-2012, 01:21 PM | #2 |
Pebble Pounder Join Date: Nov 2009 Location: pennsylvania
| Re: Best way to take slop outta chubs
I noticed mine was starting to do this i think its just going to get worse Might as well order the metal ones and call it a day
02-01-2012, 01:46 PM | #3 |
Did you double check that the metal bushings in the knuckles are there? I helped someone with a RTR Honcho with a bad front end wobble. It turned out that the top bushing on the left knuckle was missing. Replacing the bushing fixed the problem. |
02-01-2012, 02:35 PM | #4 |
bushings eh. are they plastic?
02-01-2012, 02:51 PM | #5 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
replace with metal c-hubs and knuckles. problem solved.
02-01-2012, 02:55 PM | #6 |
| Re: Best way to take slop outta chubs Nope TowerHobbies.com | AX30450 Axial Flange Pipe 3x4.5x5.5 (4) Alum chubs & knucks with beef tubes, never worry again... |
02-01-2012, 05:22 PM | #7 |
| Re: Best way to take slop outta chubs No they are steel. They are inserted into the knuckle from the inside in both top and bottom of the knuckle. The part number is AX30450. There is a picture on page 11 of the Honcho instructions The Axial aluminum knuckles (ax30496) also require the use of the steel bushing in the knuckles. |
02-01-2012, 05:53 PM | #8 |
I found this is the best way to get rid of the slop. Post #230 http://www.rccrawler.com/forum/axial...ml#post3413377 |
02-02-2012, 10:15 AM | #9 |
Rock Crawler Join Date: Apr 2009 Location: Pa
Most of the movement I see in mine is where the chub is screwed to the axle.
02-02-2012, 10:43 AM | #10 | |
| Re: Best way to take slop outta chubs Quote:
Beef tubes... | |
02-02-2012, 02:14 PM | #11 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
My golden horizons aluminum Knuckles have a lot of slop in them now.. Must be the low quality aluminum.. I just used a small drinking straw to shim them up.. I couldnt fit a complete round like I hoped.. I had to cut tiny pieces and shove them in the hole between the knuckle and the bushing.. It tightened the bushing up just enough.. If you make it too tight the steering will be to stiff and hard on the servo. Sent from my highly abused iPhone using Tapatalk |
02-02-2012, 03:32 PM | #12 |
I have Dlux kingpin bushings in my AX-10 with CKRC inner C's and Vanquish knuckles. Even after a years worth of abuse there is no vertical or horizontal play. I have D-lux kingpin bushings in my SCX with Axial inner C's and Vanquish Zero ackerman knuckles and there is just a tick of vertical play, but no horizontal. It's so minute I can't even slip a washer underneath the bushing, so I'm not going to spend time messing with it. If he'd make them for a Wraith, then it'd have them too. IMO they are as important, if not more so, than the aluminum parts when it comes to taking the slop out. Just don't put them in you old, galled, aluminum knuckes that have been run on steel bushings for a while or you won't get the same results. |
02-02-2012, 03:32 PM | #13 |
| Re: Best way to take slop outta chubs |
02-02-2012, 04:34 PM | #14 |
ah didn't even notice those when I replaced mine to aluminum. Didn't think it'd require shimming. Figured they came toleranced. I've been lookin at the beef tubes. There is so much stuff just gettin a rig together proritizin can get tricky. lol eric113's honcho flatbed now with portals those lok pretty sweet have to try those. thanks everyone. |
02-02-2012, 04:50 PM | #15 |
02-02-2012, 07:17 PM | #16 | ||
Here a link to buy the king pins. The king pins replace sleeves. They take out all play. Tamiya America Item #54237 | RC M05 Low Friction King Pin - 4pcs | ||
02-03-2012, 03:09 AM | #17 |
Yea I think I like the tamiya ones as well after lookin at a few different ones. Plus I seen somethin like this on power block about bolts bein long enough to have threads but not have threads to far up so it gets greater contact. Thanks everyone for the help |
Best way to take slop outta chubs - Similar Threads | ||||
StampedeProject.com - I'm outta here | stampedeproject | Nebraska | 2 | 08-27-2009 03:58 PM |
that's it, im outta here! | dieselfuel | Chit Chat | 2 | 11-27-2008 07:19 AM |
