02-02-2012, 01:47 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: Victoria BC
| Saggy front end on new RTR
I just bought my RTR SCX10 Honcho and noteiced after mounting the battery that the front end is very heavy and the rear isn't. The result is a somewhat saggy front end and clearly more load on the front suspension than the rear. From what I can tell, the shocks are not adjustable (aside from the dampening disks). Is there anything I can do to improve this sag?
02-02-2012, 01:53 PM | #2 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
As far as I know all the scx10 have threaded adjusters .. They are usually threaded so far up they look almost like their not there.. If you pull the spring down with your fingers you'll see the threaded shock bodies.. Sent from my highly abused iPhone using Tapatalk |
02-02-2012, 02:06 PM | #3 |
Pebble Pounder Join Date: Dec 2005 Location: W. Richland
| Re: Saggy front end on new RTR
As previously mentioned, your shocks should be dual rate. Your shock body should be threaded and the top seat for the upper coil spring can be used to adjust the preload of the shock.
02-02-2012, 03:46 PM | #4 |
Ah, good info guys - I apologize, but I couldn't locate adjustment earlier. I assumed because it was the RTR, the suspension was not adjustable. Thanks! |
02-02-2012, 05:15 PM | #5 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
My RTR just arrived today as well and i had the same deal.... and they are definitely threaded (all the way up)... i had to thread em down pretty far to even out the suspension front and back.
02-02-2012, 05:32 PM | #6 |
RCC Addict Join Date: May 2011 Location: Utah County
run it drooped. keeps your COG lower and still allows full range of articulation
02-02-2012, 06:47 PM | #7 |
set the preload on the front shocks to make up for the added weight of the battery
02-02-2012, 06:58 PM | #8 |
Rock Stacker Join Date: Jan 2012 Location: SK, Canada
| Re: Saggy front end on new RTR |
02-02-2012, 09:15 PM | #9 | |
| Re: Saggy front end on new RTR Quote:
I'd rather have droop than loss of motion. I took some pix for reference - though it's hard to see in the pic. Use the horizontal lines of the cabinet for reference. BEFORE (sag): AFTER (lifted): And some picture whoring | |
Saggy front end on new RTR - Similar Threads | ||||
WK front end | Wrampa | HPI Wheely King | 3 | 07-05-2007 01:09 AM |
Saggy front end | neo | Newbie General | 4 | 04-09-2006 05:51 AM |
