02-10-2012, 08:09 PM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
| ax-10 mip shafts on scx-10 honcho?
ok guys before you start bashing, iv searched for the past 45 mins to find this out to no avial, my LHS has some MIP shafts for an AX-10 my question is will they fit my Honch RTR, i know that they will fit the rear but will they fit the front axle and trans out puts? If this has been covered i couldnt find it, if anyone has a link instead of replying, id like to read that also, any help would be appreciated! Thanks Nate!
02-10-2012, 09:04 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: ax-10 mip shafts on scx-10 honcho?
I beleive it will fit just fine, but can't say for sure. If they don't though just a few min. with a dremel and a cut-off wheel would fix that issue. Hope this helps |
02-10-2012, 09:11 PM | #3 |
Here's a pdf of mip's for axial products to cross reference. http://miponline.com/store/media/mip...xref-axial.pdf Also search around for the wheelbase differences of the ax10, scx10 dingo and honcho. The wheelbase will give you an idea of the dshaft length needed. The drivetrain is basically identical. Come back if you have anymore questions Edit: http://www.tcscrawlers.com/On-Sale-7...1-p-16872.html Haven't found them anywhere else cheaper, also TCS is a vendor! Last edited by Meatwad; 02-10-2012 at 09:15 PM. |
02-10-2012, 09:53 PM | #4 |
im relativly sure the wheel base will be close enough to match tryi ng to figure out the pinions shaft size on the axle to see if they will fit into the mip's, thanks for all your reply's!
02-10-2012, 10:00 PM | #5 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
The axle pinions and the trans outputs are the same. Sent from my PC36100 using Tapatalk |
02-10-2012, 10:02 PM | #6 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
They will work. I converted an AX to a SCX a while back with no issues using the stock shafts.
02-10-2012, 10:10 PM | #7 |
thanks guys looking on there website it looks like the only diference is that there is a small grub screw that hold the pin in the cv joint from falling out, should be able to find or buy some of those from my LHS, thanks for all the input guys, i really apreciate it, my lhs has an ax10 mip set for $35! killer deal, just wanted to make sure they would work before i jumped on them, ill have to swing by there tomorrow ad snatch those puppies up!
02-13-2012, 11:25 PM | #8 |
Rock Crawler Join Date: Sep 2011 Location: Southern Utah
So what was your conclusion?
ax-10 mip shafts on scx-10 honcho? - Similar Threads | ||||
MIP shafts | cwettstain | Axial AX-10 Scorpion | 10 | 05-28-2010 06:05 PM |
