02-13-2012, 08:22 PM | #1 |
Newbie Join Date: Nov 2011 Location: Livermore
| scx10 problem
So I spent about an hour trying to find a solution to this problem on here and couldnt. I took my scx10 out and it seemed like the front diff was having problems maybe stripping. It would seem like the gear was hanging up and cause the whole front end to hop almost. i got home and it continued to do this. took everything apart and it seemed fine. Plugged a battery in and it did not do it. As soon as i put the two front wheels back on it started doing it again. I have no clue what this could be. Please help. If you guys need i could try to get a video of it because I'm sure i didnt explain it too well |
02-13-2012, 08:27 PM | #2 |
Pebble Pounder Join Date: Dec 2010 Location: Bay Area
| Re: scx10 problem
You may have snapped a pin or have your bead locks inside out so they are rubbing.
02-13-2012, 08:35 PM | #3 |
| Re: scx10 problem
Snapped a pin where? I had my whole differential apart and I didn't see anything wrong. All i Could think of what the bevel gear going in could be barely stripped and once a load is on (the wheels) it slips. My beadlocks are fine.
02-13-2012, 08:39 PM | #4 |
| Re: scx10 problem In the hex hub there is a pin that you may have snapped. The hex hub is what the wheels mount too and if you pull it off there is a pin.
02-13-2012, 08:50 PM | #5 |
Rock Crawler Join Date: Jun 2011 Location: Las Vegas/671
| Re: scx10 problem
I had a similiar problem, mybeadlock screw were hittingmy knuckles. try it again with putting on one wheel at a time.
02-13-2012, 08:51 PM | #6 |
| Re: scx10 problem
Just looked and they're fine.
02-13-2012, 08:55 PM | #7 |
| Re: scx10 problem |
02-13-2012, 09:02 PM | #8 |
| Re: scx10 problem
So i just looked one at a time and did not see anything contacting. It does it regardless of what wheel is on the front. I'm 99% sure they are on right. And by inside out do you mean the ring on the outside on the inside or the right ring but flipped 180? And the set screw is fine
02-13-2012, 09:06 PM | #9 | |
| Re: scx10 problem Quote:
02-13-2012, 09:07 PM | #10 |
| Re: scx10 problem
Other than that I'm out of ideas.
02-13-2012, 09:08 PM | #11 |
| Re: scx10 problem |
02-13-2012, 09:08 PM | #12 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
| Re: scx10 problem
yes the outside rings mounted onto inside of wheel, the inside ring mounted to outside of wheel. post up a video.
02-13-2012, 09:24 PM | #13 |
| Re: scx10 problem
Yeah. Time for a video.
02-13-2012, 09:30 PM | #14 |
| Re: scx10 problem
Check the drive shaft between the axel and trans, where it mounts to the transmission. You may have rounded the output. I did this one time with similar symtoms.
02-13-2012, 09:39 PM | #15 |
| Re: scx10 problem
Thanks for all the suggestions. The output is perfect (brand new) I'll get a video up
02-13-2012, 09:45 PM | #16 |
Quarry Creeper Join Date: Aug 2009 Location: here
| Re: scx10 problem
Do you have the new style drive shafts? I read on URC few people had problems with them binding on the pin in the joint. One guy said he rounded of the slot the pin travels in in the ball and that helped. I had a little bit of your problem on my Dingo when I first put it together but I installed overdrive in the front right away. I could not find what was causing it and it only did it when there was a load on the axle. I took the wheels off and it didn't do it but if I grabbed hold of the cvd it would start doing it. I got frustrated and just ran it that way and it went away after a few packs. I checked the diff gears and they seem fine so I'm hoping it was just part of breaking in the axles. |
02-13-2012, 09:50 PM | #17 | |
| 2012-02-13_20-42-10_24.mp4 - YouTube Here's a link it said quality should improve once its done being processed. It may be hard to tell but the rear is spinning consistently while the front seems to be binding, and it is vibrating. Quote:
02-13-2012, 10:02 PM | #18 |
| Re: scx10 problem
That's a lot worse then mine was. The only other thing I can think of is your pinion in too far? On my rear axle I had to open the axle up push the pinion out while installing the drive shaft to the pinion because the tolerances with the new drive shafts and the older style underdrive kit I got were pretty tight and I would push the pinion into the ring gear when I first tried installing the drive shafts.
02-13-2012, 10:08 PM | #19 |
Pebble Pounder Join Date: Dec 2011 Location: Monterey
| Re: scx10 problem
i know you said you took it apart? did you happen to check all of your axle bearings? it almost looks like you might have a bearing race locked up in there somewhere, you said it doesnt do it when the wheels are off? just when one or both of them are on?
02-13-2012, 10:09 PM | #20 |
| Re: scx10 problem
I have an MIP from an AX10 I had. There's not much room for it to compress and I'm running with the pinion angled down slightly and lowered suspension I'm going to shorten the male spline end next time I have it apart so I can angle the pinion up some more. You might want to check yours as well.
scx10 problem - Similar Threads | ||||
scx10 problem | crawling-wallz | Axial SCX-10 | 11 | 12-09-2010 08:21 PM |
scx10 driveshaft problem | j4k3 | Axial SCX-10 | 1 | 12-03-2010 07:33 AM |
SCX10 4WD problem! Help! | 4NDR3W_6THG3N | Axial SCX-10 | 11 | 08-18-2010 09:49 PM |
Problem with DX3 and SCX10 TR | RallyeX | Axial SCX-10 | 9 | 06-01-2010 09:14 PM |
