02-19-2012, 01:44 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
| I am going to Upgrade my Tranmission I need input !
Yesterday I had stripped the output gear cause I had my slipper set too tight while running a brushless motor & lipo battery I want to upgrade my transmission. I am tossed up weather I should run hardened steel gears from Hot racing with the stock the plastic case, or Would I be better off running a The all metal trans from CKRC. that includes the Metal case. When I do upgrade I will be going to a 32P Pinion/Spur also. I would appreciate some advise from those who have upgraded their Transmissions. Last edited by Tom95YJ; 02-19-2012 at 01:50 PM. |
02-19-2012, 01:59 PM | #2 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
| Re: I am going to Upgrade my Tranmission I need input !
I run Robinson racing gears in a stock case and have had no more tranny failures.It's in a honcho on 2.2's powered by a 23turn motor on a 3cell.
02-19-2012, 02:14 PM | #3 |
Pebble Pounder Join Date: Oct 2005 Location: Near D.C. (Centreville)
| Re: I am going to Upgrade my Tranmission I need input ! |
02-19-2012, 02:21 PM | #4 |
02-19-2012, 04:43 PM | #5 |
Pebble Pounder Join Date: Sep 2009 Location: joppa,al
i also run rrp gears in the stock gear case and have had no failures in a scx10 or my ax10, i upgraded to the one piece diff output/gear also.
02-19-2012, 04:44 PM | #6 |
i don't think you can mirror any of the aluminum cases if you ever decide to do that. was a factor in my decision.
02-19-2012, 04:58 PM | #7 |
Robinson Racing in the stock case |
02-19-2012, 09:43 PM | #8 |
Rock Crawler Join Date: Jan 2011 Location: Okanagan
the rpp gears are definitally worth the cash and work just fine and dandy for a true upgrade, the steel output shafts only add a sliver more metal for added strength, silly idea imo. should of done what rpp did for the additional part axial could of made a few bucks lol. oh well. depends on whether you really got the extra $$ to fork out, the added metal would be extra weight as well. adding weight to the axles is def +++ as well, where as the transmission is pretty high, adding extra weight to it does not effect the tipping point but it still does effect the CoG regardless.
02-19-2012, 09:46 PM | #9 |
Thanks for the input, With all of the replys with you guys running RRP it looks like I will be going with RRP Gears and keep the stock case. Thanks ! |
02-20-2012, 12:45 AM | #10 |
02-20-2012, 09:15 AM | #11 |
I run the Hot Racing steel gears (all 3 in a set) I was impressed for the price.. Then adding the Axial steel outputs and it's pretty solid. I don't like the one piece Robinson output gear.. Especially if you were to convert to the thru-pin design of the new Axial driveshafts or the Mips for that matter..
02-20-2012, 04:06 PM | #12 |
My SCX10 kit came with the new WB8 shafts and steel outputs
02-20-2012, 05:34 PM | #13 |
Quarry Creeper Join Date: Sep 2010 Location: Perth Australia
Im running the VP Alloy case and RRP internals on mine and im very happy with it...
I am going to Upgrade my Tranmission I need input ! - Similar Threads | ||||
Tranmission issues/questions | FlexJohnson | Axial AX-10 Scorpion | 10 | 01-16-2012 08:26 AM |
mirrored tranmission | dracbec | Axial AX-10 Scorpion | 4 | 04-18-2011 10:10 AM |
RC4WD R2 V2 tranmission | yotachump | General Crawlers | 19 | 11-13-2007 10:33 AM |
Emaxx Diff used as a tranmission | procrawler-wannabe | Traxxas Crawlers | 13 | 01-19-2006 09:47 PM |
