02-21-2012, 05:10 PM | #1 |
Newbie Join Date: Nov 2011 Location: lakewood
| Help with Tires! Please!
So this weekend i added about three ounces of weight to all four tires on my TR Dingo and now it crawls amazingly, yet now on flat straits i can see my tires are screwed 14 ways to sunday, i dont know if in the process of adding the weights i messed up the foam or what but any imput would help very much!, its like the foam is over stuffed or somthing, do you guys have an opinion?
02-21-2012, 05:45 PM | #2 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
| Re: Help with Tires! Please!
You can move the foam around inside the tires to straighten them out. It doesn't really effect anything, other than it looks kinda weird.
02-21-2012, 07:15 PM | #3 |
ya they do great, but do look weird
02-21-2012, 08:04 PM | #4 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Well straighten those puppies out!
02-21-2012, 08:33 PM | #5 |
Rock Crawler Join Date: Sep 2011 Location: Southern Utah
If your weights take alot of room you can trim the ID of your foam so they aren't being "buldged" out
10-09-2012, 02:22 PM | #6 |
Pebble Pounder Join Date: Aug 2012 Location: Canada
yeah ive encountered the same problem myself while mounting the r35 ripswaws on my axial beadlocks ...seemed like i had a bent axle ...tryed taking the wheels off and moving foams around ...problem solved...
10-09-2012, 07:10 PM | #7 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
If they are stick on weights you can always flatten them out with a hammer. Just don't nail your thumb. I did that once or twice. It will give ya a little more room for your foams.
10-09-2012, 07:55 PM | #8 |
Newbie Join Date: Oct 2011 Location: macon
i have some wat the same problem but mine goes side to side and all look fine but when in a stright line it wobbles crawlering it does good wat could that be? bent rim?
10-10-2012, 08:03 AM | #9 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: Help with Tires! Please! |
10-10-2012, 01:20 PM | #10 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
you don't always have to dismount the tires - unless your foam is pinched in the beadlock, you can usually just massage the tires and re-orient the foams inside. for all the low-speed crawler stuff this won't really make any difference other than aesthetics -- the imbalance would only really affect your RC if it was something with high-speed, or in your 1:1 rig. if you had A LOT of weight added to your wheels, like double layer, and the weights protrude past the channel on the wheel - you may choose to cut out a small amount/channel on the inside circumference of the foam where it got displaced by your weights. this is really dependent on the weight of your rig as well - for example, my rig has a good 1/4-3/8" of weights protruding past the wheel diameter, but I chose not to cut my foams because my rig weighs a good 8.5lbs - I just vent the wheels to get a little more sidewall bulge. |
