02-22-2012, 09:46 AM | #1 |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
| My SCX10 Kit Build
Hello everyone! Which drive shaft combination am I supposed to use? Thanks! Last edited by Axial Rose; 02-22-2012 at 08:28 PM. |
02-22-2012, 09:59 AM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: W. Richland
| Re: SCX10 Kit --> Which Drive Shafts? I believe I used B and D on my dingo for my initial build. Works find, drive shafts don't separate or bottom out under any circumstances. I'm going to switch to A and E for my rear now that I have a dig unit though.
02-22-2012, 10:31 AM | #3 |
Okay . . . I found my "tree" that these parts came from and from Axial's web page (LINK) I created the following image. Page 15 of the manual indicates using AX80084 5 & AX80084 1 so that's what I'll do (these are labeled "B" & "D" in the previous photo). I'll also do a better job of inspecting the trees before I cut everything off from now on (ha). |
02-22-2012, 01:25 PM | #4 |
Quarry Creeper Join Date: Feb 2012 Location: Fort Worth
So if I understand correctly whether you buy the dingo or the honcho Axial gives you the drive shafts for both?
02-22-2012, 01:45 PM | #5 |
Rock Stacker Join Date: Jan 2012 Location: SK, Canada
When in doubt, use the combination with the most length of interlacing splines lol.
02-22-2012, 02:04 PM | #6 |
| Re: SCX10 Kit --> Which Drive Shafts? |
02-22-2012, 03:22 PM | #7 |
I don't think that the RTR's come with extra shafts, just the kits. My Wraith kit came with the parts tree previously shown, which allowed me to put the wild boar shafts on my SCX because the Wraith got MIP's for an AX-10. Haven't had to try yet, but I'm pretty sure you can cut the longer ones down if you need spares. Since you can't torque check the shaft retaining bolts once installed, be sure to use loc-tite on them. Bummer the new kits come with plastic upper Y-link. |
02-22-2012, 05:01 PM | #8 |
| Re: SCX10 Kit --> Which Drive Shafts? I want to start out running this machine bone stock. Later, I plan on several upgrades, one might involve replacing the wishbone link with a four bar system. It seems fairly easy, inexpensive and fun to create a 4 bar link because I've seen others do it successfully (not that I'm very smart). |
02-22-2012, 08:27 PM | #9 |
The soldering is done - not my most favorite part of the build (ha) |
02-22-2012, 08:52 PM | #10 | |
| Re: SCX10 Kit --> Which Drive Shafts? Quote:
You can build a 4 link with the parts that come in the kit. I did buy on long screw for mine, but it is possible to build a 4 link with what you've got. Hell the 4 link trusses come with the factory parts trees now. That's the reason why I have a 4 link rear on mine. | |
02-22-2012, 09:04 PM | #11 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
| Re: My SCX10 Kit Build
Technically you can 4 link the rear and leave the 3 link upfront, three linking the rear was the worst idea ever err Axial's way of three linking that is.
02-23-2012, 01:13 AM | #12 |
Quarry Creeper Join Date: Aug 2011 Location: Troy
| Re: SCX10 Kit --> Which Drive Shafts? Generally its cheaper with injection molding to have just the one mold for all part trees rather than separate molds for each kit. Injection molds are expensive!
02-23-2012, 07:58 AM | #13 |
Thanks Optiskate, arctichorse & AG74683 I'm getting a little closer but wifey wants me to spend time w/her. Here are a few build notes which are probably only relevant to the kit I'm building: Page 23, step #29, I used part AX80005[1] instead of AX80032[1] shown Page 23, step #29, I used part AX80005[2] instead of AX80005[4] shown There are several build steps which use fasteners which are similar in size so you have to be careful. One example is on page 21, step #23 --> don't confuse the fasteners AXA0414 with AXA465. Page 19, step #18 --> omit part #AX80009[5] Make sure the axle bevel gears are seated by pulling them away from the transmission case after they have been inserted. You can probably use a 2mm hex to thread through the hole in the shaft to pull them down (no need to over do it - a simple tug works well). And a few general build notes for the newbs . . . (photos below) . . . |
02-23-2012, 11:22 AM | #14 |
One more tip. Dont build the kit while drunk. Good way to have random screws where they shouldnt be! Still finding some screws in the wrong place. |
02-23-2012, 11:51 AM | #15 |
| Re: My SCX10 Kit Build |
02-23-2012, 02:42 PM | #16 |
| Re: My SCX10 Kit Build . . . more progress . . . |
02-23-2012, 07:54 PM | #17 |
| Re: My SCX10 Kit Build It works! |
02-24-2012, 08:11 AM | #18 |
I wanted to create a decent mount for the ESC & receiver. I also wanted to create a simple way to mount the battery. This body was left over from a few years ago when I got out of crawling - I have two others I'll use later but for now, this will get me going. |
02-24-2012, 03:44 PM | #19 |
I need help! When my crawler is on the table, both of the axle input shafts are angled slightly down - not horizontal, not up. This can't be right? I am wondering about the links and I'm thinking one of the following is true: #1 --> I built it wrong #2 --> The instructions are wrong #3 --> The parts are wrong (links provided are not the right length) #4 --> More than one above In the following photos, you can see the metal links that came with my kit. All four of these (2 front & 2 rear) measure ~122mm center-to-center. Also, you can see from the image taken from the instruction manual for an earlier version of the SCX-10, the links that came with the older SCX10 (the plastic ones) measure ~114mm center-to-center. I thought both of the axle input shafts were supposed to tilt up, not down. Any help with this is most appreciated. MEGA-THANKS!!! Last edited by Axial Rose; 03-21-2012 at 08:51 PM. |
02-24-2012, 05:30 PM | #20 |
Rock Stacker Join Date: Jan 2012 Location: Fall River
You need new upper links the right length for the lowers you have. That's just how the kit is. The short ones were too long to 4 link my Dingo kit. :\ 10mm shorter upper links is a good starting point. That's gotten me where a washer or 2 will set the pinion angle decently for me. Last edited by Dudeman; 02-24-2012 at 05:38 PM. |
My SCX10 Kit Build - Similar Threads | ||||
MIP Drive Shafts for SCX10 | jray | Newbie General | 9 | 08-15-2011 04:30 PM |
scx10 drive shafts | mikeman84 | 1.9 Scale Rigs | 5 | 10-28-2010 05:18 PM |
SCX10 MIP C-Drive Spline Shafts | casepuller | Axial SCX-10 | 1 | 03-05-2009 08:18 PM |
