Thread: do I have to change ?
Old 02-25-2012, 02:34 PM   #1
Default do I have to change ?
Do I have to change gearing if I decide to run 2.2 ?
DirtMan1989 is offline   Reply With Quote
Old 02-25-2012, 02:38 PM   #2
ScaleFreak93's Avatar
Default Re: do I have to change ?
Do you want to change gearing? You're not giving us much to work with here. A little more info would be nice.
ScaleFreak93 is offline   Reply With Quote
Old 02-25-2012, 03:08 PM   #3
what i am tryin to say do i have to change if i want to run 2.2 tires
Old 02-25-2012, 03:17 PM   #4
If you are trying to say to change from 1.9 to 2.2 tires,i did not change gears but i have a 45t motor
jvella is offline   Reply With Quote
Old 02-25-2012, 03:32 PM   #5
all these noobs... haha..
to answer your question, No you dont. i went from 1.9's to 2.2's on scx10 and im running the stock gears and a 55 turn motor. the only time i'd change the gearing is if i wanted to overdrive the front, makes the front tires spin faster than the rear for a tighter turning radius and helps on climbs.
what body are you running? i know with the honcho body you have to either trim the shit out of the body or make a lift.
AX10wannabe is offline   Reply With Quote
Old 02-25-2012, 03:47 PM   #6
I understand what you were asking, but what turn motor do you have? What gearing do you currently have? Do you have different gearing in your axles? These are what I was wondering. You don't need to change your gearing but you may if your motor is getting to hot.
Old 02-25-2012, 04:07 PM   #7
ok.. i see . see i am buying the newest honcho rtr soon and i wanted to kno if i had to change anything out of the box by throwing some 2.2 at it and it is a 27t motor ..
Old 02-25-2012, 08:16 PM   #8
Well what 2.2's? If they are a larger one you might get a slightly smaller pinion and if they're not on the larger side you'll probably be ok.
Old 02-25-2012, 09:25 PM   #9
Yup, if your going to a larger diameter
Tire, you could go to a slightly smaller pinion, it's just like a real truck, if you go from stock tires to larger offload tires, your gonna want a lower gearing.
rocksteadily is offline   Reply With Quote
Old 02-25-2012, 10:03 PM   #10
heinie_21's Avatar
just save the headache of gearing and dont go to 2.2's... they look silly on a scaler. When was the last time you saw a toyota truck on 55" tires?
heinie_21 is offline   Reply With Quote
Old 02-25-2012, 10:35 PM   #11
heinie_21's Avatar
How to get in the kraken - YouTube
i stand corrected...
Old 02-25-2012, 11:03 PM   #12
Agree, I went down that road. Does it make the rig more capable?? Yes. Does it look stupid??? Yes..........Went with Rok-Lox 1.9s, as tall as some 2.2's but looks way more scale.
ridepate is offline   Reply With Quote
Old 02-26-2012, 03:00 AM   #13
thanks..
do I have to change ? - Similar Threads
what to change? theclimber Axial Wraith 5 06-28-2011 04:26 AM
Name change LumTheMad Comments, Suggestions, and Help 6 10-25-2008 08:32 AM
Name Change? Shaun Comments, Suggestions, and Help 17 09-20-2008 09:21 AM
