02-25-2012, 02:34 PM | #1 |
Newbie Join Date: Feb 2012 Location: Phoenix
| do I have to change ?
Do I have to change gearing if I decide to run 2.2 ?
02-25-2012, 02:38 PM | #2 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: do I have to change ?
Do you want to change gearing? You're not giving us much to work with here. A little more info would be nice.
02-25-2012, 03:08 PM | #3 |
what i am tryin to say do i have to change if i want to run 2.2 tires
02-25-2012, 03:17 PM | #4 |
Pebble Pounder Join Date: Jul 2010 Location: malta
If you are trying to say to change from 1.9 to 2.2 tires,i did not change gears but i have a 45t motor
02-25-2012, 03:32 PM | #5 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
all these noobs... haha.. to answer your question, No you dont. i went from 1.9's to 2.2's on scx10 and im running the stock gears and a 55 turn motor. the only time i'd change the gearing is if i wanted to overdrive the front, makes the front tires spin faster than the rear for a tighter turning radius and helps on climbs. what body are you running? i know with the honcho body you have to either trim the shit out of the body or make a lift. |
02-25-2012, 03:47 PM | #6 |
I understand what you were asking, but what turn motor do you have? What gearing do you currently have? Do you have different gearing in your axles? These are what I was wondering. You don't need to change your gearing but you may if your motor is getting to hot.
02-25-2012, 04:07 PM | #7 |
ok.. i see . see i am buying the newest honcho rtr soon and i wanted to kno if i had to change anything out of the box by throwing some 2.2 at it and it is a 27t motor ..
02-25-2012, 08:16 PM | #8 |
Well what 2.2's? If they are a larger one you might get a slightly smaller pinion and if they're not on the larger side you'll probably be ok.
02-25-2012, 09:25 PM | #9 |
RCC Addict Join Date: Mar 2009 Location: hawaii
Yup, if your going to a larger diameter Tire, you could go to a slightly smaller pinion, it's just like a real truck, if you go from stock tires to larger offload tires, your gonna want a lower gearing. |
02-25-2012, 10:03 PM | #10 |
RCC Addict Join Date: May 2011 Location: Utah County
just save the headache of gearing and dont go to 2.2's... they look silly on a scaler. When was the last time you saw a toyota truck on 55" tires?
02-25-2012, 10:35 PM | #11 |
| Re: do I have to change ? |
02-25-2012, 11:03 PM | #12 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
| Re: do I have to change ? Agree, I went down that road. Does it make the rig more capable?? Yes. Does it look stupid??? Yes..........Went with Rok-Lox 1.9s, as tall as some 2.2's but looks way more scale.
02-26-2012, 03:00 AM | #13 |
thanks..
do I have to change ? - Similar Threads | ||||
what to change? | theclimber | Axial Wraith | 5 | 06-28-2011 04:26 AM |
Name change | LumTheMad | Comments, Suggestions, and Help | 6 | 10-25-2008 08:32 AM |
Name Change? | Shaun | Comments, Suggestions, and Help | 17 | 09-20-2008 09:21 AM |
