02-27-2012, 04:45 PM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: tampabay
| Hot Racing 100MM Shocks
Worked out very well. Front tire setting on a 4 inch glass. |
02-27-2012, 06:31 PM | #2 |
Pebble Pounder Join Date: Dec 2005 Location: W. Richland
| Re: Hot Racing 100MM Shocks |
02-27-2012, 06:41 PM | #3 |
Yes the reservoirs are functional I just have to get all the air out of the lines and its has about 4 1/4 inch of travel the stocks looked and felt cheap to me Sorry Axial. Please don't take it the wrong way guys the shock thing is just my opinion and you know what they say a opinion. lol
02-27-2012, 07:13 PM | #4 |
Thats pretty cool. I wonder if you'd really see a benefit from running a remote res shock in an RC crawler. Travel wise I meant how much more over all travel are the shocks, not how much longer are the shock extended. lol I'm going to have to measure how much travel I'm getting now since I know you're getting your tire 4.25" up.
02-27-2012, 07:24 PM | #5 |
I am really new to this but having a lot of fun. my thing is the build part. I also order some aluminum front and rear bumper mount. If you saw my video on the 3 racing winch i thought the bumper was getting pulled off. lol
02-27-2012, 09:20 PM | #6 |
I didn't see that video, but I'd love to. You should post a link up. I've had my frame twist up when I get hung up on stuff. I've also thought I was going to rip my body off a couple times. I like to drive hard, what can I say. I've thought about aluminum cross members but their expensive and it still adds weight up high. |
03-01-2012, 11:43 AM | #7 |
Update I have 20 wt oil in the shocks at this time. However I believe that its still to heavy of a oil. I did buy 17 1/2wt losi oil. Lets see how this goes . Also have the gold springs in the rear and sliver in the front.
03-03-2012, 11:26 AM | #8 |
17 1/2 wt shock oil did not like the 20
03-03-2012, 02:56 PM | #9 |
Could it be that the shocks are over filled maybe? I know my shocks are stiff as hell and rebound hard when they're over filled. I run 30wt and with my shocks filled properly they cycle almost effortlessly.
03-03-2012, 03:15 PM | #10 |
Rock Crawler Join Date: Jul 2011 Location: Incirlik AB, Turkey
I have these shocks as well and stopped using them cause I couldn't seem to get all the air out on one shock. Do you have any tricks of the trade? how do you fill yours? |
03-03-2012, 05:02 PM | #11 |
| Re: Hot Racing 100MM Shocks I have used over 50 black small wire ties. At this time i am go with the black springs and 17 1/2 wt losi shock oil. Now for the air thing no clue. But I can tell you that I got a new pack of 100 wire ties.
03-03-2012, 05:19 PM | #12 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
I used the shocks with no oil, just enough to keep them lubed. They will not work correctly filled with oil. The design of the c-clips holding the piston on is flawed. They cover the slot in the piston, which is not large enough anyways, resulting in very lathargic shock-action, no matter what weight oil you use.. You can attempt to line-up the c-clip slots with the piston slot, but they will move back over the slot. They did work ok with no oil, kinda boingy tho. I finally bought some real shocks...........Pro-Line 6060's |
03-03-2012, 05:23 PM | #13 |
Quarry Creeper Join Date: Aug 2011 Location: Troy
| Re: Hot Racing 100MM Shocks Sorry if I'm just blind, but what do wire ties have anything to do with these shocks, short of holding on the reservoir..?
03-04-2012, 08:12 AM | #14 | |
| Re: Hot Racing 100MM Shocks Quote:
03-04-2012, 10:47 AM | #15 |
03-04-2012, 03:58 PM | #16 |
all set now |
03-05-2012, 01:17 AM | #17 |
Do you have more pics of the mods you did to the shocks? I'm not 100% sold that remote res will be beneficial on an RC scale. Its cool, but how does it affect performance for you? How do they perform and do you like them? How do they compare to other shocks you have run.
03-05-2012, 05:42 PM | #18 | |
04-25-2013, 08:10 PM | #19 |
Pebble Pounder Join Date: Nov 2012 Location: imperial
I have them and love them. Would not trade them for the world. Check out my GoPro vid. |
Hot Racing 100MM Shocks - Similar Threads | ||||
100mm Hot racing Shocks | xslashguy | Axial SCX-10 | 2 | 02-24-2012 08:02 PM |
Hot racing 100mm remote res shock | Heath49 | Axial SCX-10 | 4 | 02-05-2011 11:51 PM |
NEW Hot Racing 100mm Scale Shocks | RPP Hobby | RPP Hobby | 15 | 04-14-2009 07:45 PM |
hot racing shocks for ax-10 | Trimmy | Newbie General | 2 | 01-17-2008 06:17 AM |
