04-13-2012, 01:23 AM | #1 |
Newbie Join Date: Sep 2008 Location: San Jose
| Need help with my Dingo build
Im ordering a dingo today and need some help. 1. Im going to order ARB T-rex 60 axles, what else do I need to install them properly? I couldnt find a clear answer with suggested parts ARB Special Edition T-Rex 60 Front & Rear Plastic Complete Axle 2. I want a CMS, but unsure which one I need. The "3 link" is throwing me off a bit Hand Brothers Off Road*-*Manufacturers*-*The Crawlers Store LLC Is there anything else i should look into or be concerned about? Ive heard mixed reveiws about the t-rex axles, but I love the look of them. Thanks for your time |
04-13-2012, 04:39 PM | #2 |
Rock Crawler Join Date: Sep 2011 Location: Southern Utah
| Re: Need help with my Dingo build
I got my axles used and they came with everything, but I still may be able to help. Looking at RC4WD's website, it looks like those axles come with 1x ARB Special Edition T-Rex 60 Plastic Front Axle 1x ARB Special Edition T-Rex 60 Plastic Rear Axle 4x 4 Link and Shock mounts 8x M3 Hardware They come with the (qty 4) link and shock mounts because you need the shock mounts whether or not you do 4 link or leaf springs. If you want to do leafs you need this Leaf Spring Mount for T-Rex Axle if you already have leafs, or this Simple Leaf Spring Mount Kit for T-Rex 60 Axle if you don't. In order to do 3 or 4 link all you need are these T-Rex 60 Axle Servo Mounts or this T-Rex 60 Axle 3 Link kit I have that whole 3 link kit and to make it 4 link you take the 3 link post off and use the 2 holes that mount the post for each upper link. Not sure if this is correct or what RC4WD intended, but it worked for me. Here's mine 3 link front, 4 link rear. Hope this helps. |
04-14-2012, 12:15 AM | #3 |
Thank you for all the help! This definitely answered my questions, I appreciate it
04-06-2013, 08:03 AM | #4 |
Rock Crawler Join Date: Jan 2013 Location: Australia
Sorry to resurrect an old thread, but I'm not sure about what I need for these axles. I'm doing a chassis mounted servo, so do I still need to servo mount for the other thing that comes with it? Also it says on post 2 all I need is the 3 link mount and the servo mount, what about the rear 4 link? Sorry if I'm being a nuisance, I'm just not sure. Cheers, Hammer |
04-06-2013, 08:06 AM | #5 |
Sorry forgot to add, could I do 3 link on front AND rear?
04-06-2013, 08:10 AM | #6 |
Once again, sorry! XP ignore the post above me, I just figured it out. Sorry about the triple post as well.
Need help with my Dingo build - Similar Threads | ||||
Axial Dingo / JK Build | Black Venom | Axial SCX-10 | 97 | 01-20-2013 12:16 PM |
Bronco2x84's DINGO TR Build | Bronco2x84 | Axial SCX-10 | 3 | 02-15-2012 02:58 PM |
My Dingo build sort of. | BillH | Axial SCX-10 | 9 | 02-06-2012 06:46 PM |
dingo kit build | sheeno | Axial SCX-10 | 21 | 02-05-2012 01:35 PM |
Dingo Build up. | mwscooters | Axial SCX-10 | 27 | 10-12-2011 03:27 PM |
