04-20-2012, 11:11 PM | #1 |
Quarry Creeper Join Date: Feb 2012 Location: Canada
| SCX10 Shock upgraded Shock hoops
Are they worth upgrading? I know VP makes them for the SCX10 out of aluminum. Any pros/cons of this upgrade? |
04-20-2012, 11:35 PM | #2 |
Newbie Join Date: Aug 2009 Location: wyoming mich
| Re: SCX10 Shock upgraded Shock hoops
shock ok but if not broke don't change it that what i did
04-21-2012, 08:14 PM | #3 |
RCC Addict Join Date: Dec 2007 Location: (LES) Manhattan, New York
I have the stock shock hoops on one rig and Vanquish aluminum hoops on another. I agree with the "if it aint broke, don't fix it" motto but not it this case. The stock hoops work fine and should last quite a while but they flex. Keep in mind that the body is attached to the hoops so that would increase flex. The rig with the Vanquish stock has no such flex issues and that's how I prefer it. For the record...I'm going to order a new set from Vanquish for my other rig. Hope this helps! |
04-21-2012, 09:48 PM | #4 | |
| Re: SCX10 Shock upgraded Shock hoops Quote:
04-21-2012, 10:30 PM | #5 |
The Vanquish hoops are you still able to use the stock body posts?
05-15-2012, 07:48 PM | #6 | |
I have a heavy rig with steel front , rear, and side bumpers. I prefer the stability of aluminum hoops. if you wish to keep the original hoops but add some stability then you might consider place a link between the two hoops. Yes, you will be able to use the stock body posts. It will also keep your truck body stable. Last edited by Lobonyc; 05-15-2012 at 07:52 PM. | |
05-15-2012, 08:02 PM | #7 |
I barely trust the stock plastic shock towers as body mounts, much less structural to the suspension's operation. So I whipped up some ghetto shock relocation/chassis stiffeners/slider raisers out of a couple pieces of road sign. It would be super easy to just make 4 triangles to bolt to the stock chassis and drill your own shock mounts wherever you'd like. Last edited by meatmonkey; 05-15-2012 at 08:04 PM. Reason: my compuer illiteracy |
05-17-2012, 09:37 AM | #8 | |
NICE!!! | |
05-17-2012, 09:47 AM | #9 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| Re: SCX10 Shock upgraded Shock hoops |
05-17-2012, 11:13 AM | #10 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
sure you could do all that stuff mentioned above, but if you want to save $ and weight just make a simple brace that ties the two towers together with a piece of rod or brake line. if you don't have a tap, use brake line and put a dab of shoe-goo in the ends to hold your threads. works very well for a $0.50 fix |
05-17-2012, 11:33 AM | #11 |
Pebble Pounder Join Date: Jun 2010 Location: bowling green
Another way too make a cheap brace is to use a plastic coat hanger cut it to size get a use a 2.5 mm drillbit then the screw will thread its self I've made a lot of braces and upper links this way
05-17-2012, 11:46 AM | #12 |
Quarry Creeper Join Date: Mar 2011 Location: over there...
I have the vp ones ,but i don't think its needed just mostly bling ,the stock one don't flex there about the same .I think the flex comes from the classis not the towers .imo
05-17-2012, 12:13 PM | #13 |
05-18-2012, 09:05 AM | #14 |
Newbie Join Date: Oct 2005 Location: Rocklin
Thanks for the great ideas. I went ahead and found and old pan car anti flip carbon fiber rod i chopped into a shock mount brace. |
05-18-2012, 10:59 AM | #15 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
Now your thinking and saving....nice work!
05-18-2012, 12:13 PM | #16 |
Thanks Desert Rc!!! The cool thing is the carbon fiber tube was scrap from my old RC10L pan car from 20+ years ago I used a longer screw for the shocks which I go from my old 3 link thanks for the help from the search button here... I have a total of zero dollars invested in this. Last edited by Bill8Bud; 05-18-2012 at 12:17 PM. |
