05-22-2012, 10:21 PM | #1 |
Rock Stacker Join Date: Mar 2012 Location: middletown ohio
| stronger front axle shafts with cvd?
I may have a way to make some just seeimg if ne one makes them?
05-22-2012, 11:38 PM | #2 |
Pebble Pounder Join Date: Jul 2010 Location: malta
| Re: stronger front axle shafts with cvd?
More than these Super 300 interest |
05-23-2012, 09:29 AM | #3 |
Thanks for the link. Im working on a,set of venom creeper shafts to fit my scx10 I've modded them to fit and will jave thin in tonight if all go well
05-26-2012, 03:48 PM | #4 |
ok so had to shorten one of the shafts to mach the length of the stock shafts. then you have to file the inner end to match the stock shaft's inner end and presto. you will have to use different drive flanges i used the ones off the venom creeper and just filed the collar off them. they seem to work good, no binding.
05-26-2012, 08:20 PM | #5 |
Look into the xr10 universals mod. Pretty durable so far for my heavy trigger meatfinger |
06-01-2012, 08:06 PM | #6 |
will do. ill prob just run these till they break, just to see how strong they are.plus I have another set laying around trying to keep cost down.
06-28-2012, 01:20 PM | #7 |
Rock Crawler Join Date: Dec 2008 Location: dallas
When we did the original strength testing of all the different shafts a few years back, the Creepers where close to the bottom for strength. The axial cvds where pretty strong as long as they arent oversteered, from there you can install the XR uni's (though that would require different knuckles), moving up the line to my original 300's, and then to the 300HD's for the ultimate in strength and durability(the last shaft you will buy). Hope this helps |
06-28-2012, 01:27 PM | #8 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
06-28-2012, 03:05 PM | #9 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
xr10 is probably the most cost effectve/easiest... people toss the plastick c's and knuckles, so you could probably get those cheap/free, your scx bearings will fit in the knuckle, you just need to buy a set of axle shafts, cut them to size, grind them down so they fit in the locker, and you're good to go.
06-28-2012, 03:49 PM | #10 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
Vanquish is almost ready to release their CVD's.
stronger front axle shafts with cvd? - Similar Threads | ||||
Stronger axle shafts? | suzuki | Axial Wraith | 4 | 09-22-2011 12:21 PM |
Stronger Axle Shafts? | kazuaki | HPI Wheely King | 1 | 07-25-2010 05:04 PM |
Front Axle shafts falling out!??? | Kratos | General Crawlers | 4 | 03-22-2010 03:23 PM |
front axle shafts | derekshep | Tamiya XC/CC01 | 2 | 03-08-2010 11:40 AM |
