07-08-2012, 08:37 PM | #1 |
Rock Crawler Join Date: Jul 2011 Location: Incirlik AB, Turkey
| steerin servo issue
So my old servo took a poo and replaced it with a heavy duty metal gear one but now when I turn either way my truck twitches. Do I now need the BEC?
07-08-2012, 09:07 PM | #2 |
Quarry Creeper Join Date: Dec 2011 Location: Colfax, NC
| Re: steerin servo issue
You might need to adjust your EPA settings.
07-08-2012, 09:14 PM | #3 |
Might want to check and turn down your EPA's (if you radio has them), sounds like you're binding and stalling at the end of your travel. If your radio doesn't have EPA's you can set, maybe a shorter servo arm would fix it. But if you've upgraded your servo, I really think you should have done the BEC, too. And don't forget the CastleLink if you don't already have one. (Assuming you go CC BEC) |
07-09-2012, 11:49 AM | #4 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Most likely, yes, you need a BEC. What ESC are you running?
07-09-2012, 05:48 PM | #5 |
I am runnin the Tekin, EPA eh, I have the futaba 4ch txr.
steerin servo issue - Similar Threads | ||||
servo issue??? | jessejoe23 | Electronics | 4 | 08-29-2011 11:47 AM |
Servo issue | ohmyCLOD! | Electronics | 0 | 05-04-2009 04:39 PM |
Where to get TXT steerin knuckles? | Tacoma747 | Tamiya Txt-1 and Juggernaut | 2 | 09-16-2007 10:53 AM |
bad steerin | z71er1c | General Crawlers | 14 | 12-14-2006 03:55 PM |
