10-17-2012, 07:22 PM | #1 |
Newbie Join Date: Sep 2012 Location: salina
| servo mount
just wantin to get some feedback on mountin the steerin servo on the chassis... i heard from a guy here that he didn't like it very much. does it hinder the articulation at all or anything like that???
10-17-2012, 07:47 PM | #2 |
Pebble Pounder Join Date: May 2011 Location: The Wizzle, MA
| Re: servo mount
Chassis mounted steering is only done for the scale factor. If you're looking for performance, axle mount has it beat in almost every regard.
10-17-2012, 07:57 PM | #3 |
Rock Crawler Join Date: Apr 2009 Location: Pa
| Re: servo mount
I made a chassis mount for the servo and 4 linked the front. I like the 4link setup but do not really like the chassis mounted servo.(front wheels turn slightly when suspension is compresses and rebounds) Going to put the old axle mount servo/4 link plate back on for now. May consider the hand brothers kit or make my own parts in the future. Maybe I will will keep it on the axle. Depends on if I have the time.
10-17-2012, 09:14 PM | #4 |
| Re: servo mount
Ok thanks a bunch man i appreciate it
10-17-2012, 09:50 PM | #5 |
Quarry Creeper Join Date: Nov 2010 Location: land of no rocks
| Re: servo mount
i didnt like it bc of high torque sevros and heavy wheels my frame would twist. so i lost all that torque in twisting the frame then turning the tires.
10-17-2012, 11:14 PM | #6 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
| Re: servo mount
The ONLY way to do a chassis mounted servo is with a 3 link/panhard setup. The draglink needs to be the same length and and angle as the panhard bar. If you look at the hand bros. kit you will see a very well engineered front suspension/steering setup that works great. It does limit vertical travel somewhat but that means nothing. Articulation is smoother and the steering follows the suspension perfectly. Running a axle mounted servo is for comp rigs IMO.
10-17-2012, 11:49 PM | #7 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
CMS can and has been done just fine with 4links. Look at a stock jeep. The links must be straight. The wheels moving is bump steer and like states without the links being tuned correctly it will happen. Is it going to hinder your driving? Not enough for you to notice unless your either really good driver or going really fast. Even then if you can tell you can drive through it. It's done for the scale factor or looks if you will. |
10-18-2012, 01:27 PM | #8 | |
| Re: servo mount Quote:
10-18-2012, 04:09 PM | #9 |
| Re: servo mount
I have a chassis mounted servo, and still run the stock 3 link in the front with no panhard bar. Like doublej said, the bumpsteer is very slight, and nothing that can't be driven out of. Would I drive a 1:1 truck like this at highway speed? No way, but for toy trucks it's fine.
10-18-2012, 04:48 PM | #10 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: servo mount
i run homebrew CMS with front 4-link. it does have slight bump steer but it's not enough concern for me to redo the whole front end....but might happen eventually just because - but so far so good |
servo mount - Similar Threads | ||||
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 228 | 07-12-2011 01:17 PM |
***Crawler Innovations Servo Guard-Servo Clamp-Servo Mount GIVEAWAY*** | Nova's Ark | General Crawlers | 266 | 04-01-2011 02:18 PM |
Crawler Innovations Servo Guard - Servo Clamp - Servo Mount GIVEAWAY!!! | Nova's Ark | General Crawlers | 219 | 10-18-2010 12:43 PM |
BWD Modular Servo Mount/Battery Tray/Adjustable Upper Link Mount | billet works | HPI Wheely King | 18 | 07-05-2010 10:52 AM |
