11-09-2012, 07:57 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: Doylestown
| Axial aluminum shocks Leaking??? Pics
So I purchased a set of Axial Aluminum threaded shocks. They were too long so decided to shorten the eye to eye down to 4" using fuel line. I removed the body, nut and black piece under the top nut. I then slid the roughly 1/4" piece of fuel tube and reinstalled the shocks...Voila...shortened. My problem is that I filled them today with 20wt silicone oil, bled them, and reassembled. I now have some slight leaking of oil around the bottom of the shock body around the black threaded piece that meets the body. Not sure why this is happening and wondering if anyone has any feedback for me or a fix. Should I use thread pipe tape on the threads?? Last edited by mcap; 11-09-2012 at 08:03 PM. Reason: fix pic |
11-10-2012, 02:14 AM | #2 |
Newbie Join Date: Mar 2011 Location: bismarck
| Re: Axial aluminum shocks Leaking??? Pics
its prob coming from the orings that seal the shock shaft inside the black bottom peace. you nicked them in the disassemble reassembly process. gotta be carful
11-10-2012, 06:34 AM | #3 |
The black bottom piece has a thin 6 sides area to unscrew it from the shaft. The inside is just threads so not sure how I could've messed it up. I'll take a closer look
11-10-2012, 07:04 AM | #4 |
Rock Stacker Join Date: Mar 2009 Location: Holland
Inside the black bottem piece is a rubber ring ( o-ring). Mabey its dammaged. |
Axial aluminum shocks Leaking??? Pics - Similar Threads | ||||
Axial comp shocks leaking | Pro RC 93 | Axial AX-10 Scorpion | 14 | 06-28-2010 09:08 PM |
Shocks keep leaking | Alex's revo 3.3 | Axial AX-10 Scorpion | 13 | 01-08-2010 01:19 AM |
Leaking shocks....???? | Ritter1 | Team Losi Comp Crawler | 4 | 08-14-2009 02:28 PM |
