Thread: Help!
Old 01-02-2013, 05:35 AM   #1
Default Help!
Im just finished building my dingo kit. When i turn the wheels, the driveshafts have a good amout of resistence. I think i got thread lock in the yoke area :(
Any ideas on how to fix it?
Also, i dont have alot of travel, the shocks are stiff... What can i do to fix tht (i used the schock oil given...)
solly98 is offline   Reply With Quote
Old 01-02-2013, 08:38 AM   #2
In the band for now.
Default Re: Help!
take the d shafts apart and clean out the loctite.
as for the shocks maybe you put to much oil in them
lemonhead is offline   Reply With Quote
Old 01-02-2013, 09:55 AM   #3
Default Re: Help!
Shocks:
It sounds like you need to bleed the shocks. You can trap air when putting on the cap which will make the shocks very stiff.
Also you need to make sure that the piston travels smoothly in the shock body. The little nib of plastic that attaches the piston to the tree will also make the shock stiff.
Here is a video that shows how to bleed the shocks.
Build the Axial SCX10 #9 Page by Page - YouTube
k7zpj is offline   Reply With Quote
Old 01-02-2013, 07:55 PM   #4
Default Re: Help!
Not sure about the driveshafts, but for the shocks you either have too much oil, air trapped or a little plastic nub on the piston grabbing the shock body. Did you bleed the shocks when you assembled them, or fill them up all the way to the top?
canadianbacon is offline   Reply With Quote
Old 01-03-2013, 05:45 PM   #5
Default Re: Help!
I don't know if you have same problem as mine. I found the problem is the yoke has too much angle that cause drive shaft resistance. The driveshafts are running smoothly after applying some grease on all yokes.
errorbug is offline   Reply With Quote
Old 01-03-2013, 11:27 PM   #6
Add some spacers to the upper/lower links to get a better pinion angle I just adjusted mine and its as smooth as buttah
Sent from Outerspace Using My iFreeze Ray Gun
Big Tex is offline   Reply With Quote
