11-26-2012, 08:23 PM | #1 |
Rock Stacker Join Date: Oct 2012 Location: CT
| Short wheel base drivetrain solutions.
I am going with a short body on my honcho frame so I moved the rear axle up an inch or two. I understand how difficult it is with this frame to have a short wheel base and steep drive shaft angles but what are some solutions. Do they make better driveshafts that can work on steeper angles? should i move the transmittion forward on the frame or maybe drop it down a little? I've been maybe looking into getting one of those Dinky RC split skid set-ups.. let me know what you think.. thanks |
11-26-2012, 08:54 PM | #2 |
RCC Addict Join Date: May 2011 Location: Utah County
Adjust your link lengths to point the rear axles' pinion upwards. You can get away with shorter wb that way. I've run like a 10"wb with no driveshaft binding. Sent from my SCH-I535 using Tapatalk 2 |
11-27-2012, 06:28 AM | #3 |
Quarry Creeper Join Date: Feb 2012 Location: Near the IL/WI border
| Re: Short wheel base drivetrain solutions.
Shorten the length of your upper links. (Assuming you have it 4-linked.) What you want to do is shorten the links enough to rotate the axle pinion upward. Ideally the driveshaft should form a straight line from the axle pinion to the transmission. I did this on my Dingo with 2.2s and it works great. No binding at all. Hope this helps! |
11-27-2012, 07:20 AM | #4 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
If you shorten the uppers it'll rotate the pinion down. You want to shorten the lowers.
11-28-2012, 08:46 AM | #5 |
AxMan is correct. I LENGTHENED the upper links, while maintaining the stock wheelbase with the stock lower links. Sorry for that. |
Short wheel base drivetrain solutions. - Similar Threads | ||||
xr 10 with 2009 Jeep rubicon short wheel base body | dusty sweep | 2.2 Scale Rigs | 3 | 11-23-2011 11:12 PM |
Hows this for short wheel base? | murdock | Chit Chat | 0 | 06-11-2011 12:08 PM |
honcho on a small wheel base? and advantage of the long wheel base? | Daddydancool | Axial SCX-10 | 7 | 04-26-2011 06:29 PM |
