Thread: Jevne Batt./Servo Plate With Servo Winch Installed?
Old 12-11-2012, 05:19 PM   #1
Default Jevne Batt./Servo Plate With Servo Winch Installed?
Im considering installing one of these plates, but I am hoping to see some pic's of people's setup's with a servo winch installed first before I purchase one
I see there are 3 versions available currently.
The "Ultra Plate"
Jevne Racing "Ultra Plate" SCX10 Battery Plate
The "Recon Brick Plate"
Jevne Racing "Recon Brick Plate" SCX10 Battery Plate
The "CMS Brick Plate"
Jevne Racing "CMS Brick Plate" SCX10 Battery Plate
Best I can tell, the only difference between the first 2 is the Recon has "ears" to prevent the batt. from sliding out the side...?
The CMS version is obviously different in the way it is cut for steering servo clearance. I do not have CMS (yet?), I've been pondering the install, but Im still not completely sold on the idea.
Is there any benifit other than a slightly more scale appearance and additional scale comp points received when running a chassis mounted steering servo?
If you are running any one of these plates with a servo winch installed please post up a pic or two along with any like/dislike comments (IE;would you change anything if you could do it over again?) regarding your setup.
Thanks!
BodiBuilt is offline   Reply With Quote
Jevne Batt./Servo Plate With Servo Winch Installed? - Similar Threads
Servo Winch mounting plate mud_life_19 General Scale Talk 5 08-30-2012 12:43 PM
Servo winch installed, now causes steering issue Harry Handcuffs Electronics 2 12-29-2011 07:16 PM
batt/servo plate for moa??? Mudsy Team Losi Comp Crawler 1 11-29-2010 09:11 AM
help!! aftermarket servo batt plate jreckner Axial AX-10 Scorpion 6 10-09-2008 08:31 AM
