Thread: vanquish knuckles
Old 01-08-2013, 10:12 AM   #1
Default vanquish knuckles
I am looking at getting some new knuckles for my truck and was looking at the vanquish knuckles, the high steer and the 8 degree, what does the 8 degree do for the truck, what does the 8 degree stand for?, anybody using any of these, what are you thoughts on them?
Bronco2x84 is offline   Reply With Quote
Old 01-08-2013, 11:11 AM   #2
DISTURBIN' tha PEACE's Avatar
Default Re: vanquish knuckles
The 8* is the kingpin inclination. Gives you less wheel scrub while turning.
Do a quick search on kingpin inclination & you'll get more info.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 01-08-2013, 11:45 AM   #3
ok I got a good insight into tbe kingpin inclination and steering set up but now, does the high steer help more or does the 8 degree kingpin help more from personal experience
Old 01-08-2013, 11:47 AM   #4
depends what you want the 8* is 8 degrees of caster, it makes your wheels lean over when turning, scale guys don't like it because it's unrealistic, but it does give you increased turning and allows your tires to clear the shocks better in high steer applications.
T3rry is offline   Reply With Quote
Old 01-08-2013, 11:49 AM   #5
cant say its too unrealistic, my bronco does that when cranked to one side, so the high steer do the same as the 8 degree but being more realistic?
Old 01-08-2013, 01:00 PM   #6
no, the high steer is vertical kingpin (standard), but locates the arm/linkage closer to chassis. benefit is that now a straight steering link will not hit the diff/bulge on the axle, and the knuckle arms won't hit the mounting screws for the C-hubs anymore, thus allowing max steering travel (if you have CVD's and EPA adjustment to allow this)
someone can correct me, but similar effect to the 8* setup is to simply clock your c-hubs back a couple degrees so that when turning, the caster angle changes. this can be done with clockable C's or with non-adjustable C's + new holes drilled in the housing and beef tubes inside to anchor to.
Perkolator is offline   Reply With Quote
Old 01-08-2013, 01:04 PM   #7
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Almost every axle on the road has king pin inclination. And the 8 degree does not stand for caster.
Harley is offline   Reply With Quote
Old 01-08-2013, 01:06 PM   #8
The VP 8* knuckles are also high steer.
The VP High steer knuckles have 0* inclination.
Hope that helps.
Old 01-08-2013, 02:54 PM   #9
ok so the 8 degree knuckles are best bang for your buck when trying to go high steering as well as moving the link up so it ckears the diff also giving a little more clearence in the front, correct? so after that I need a new radio and new cv axles?then my front steering will be maxed out mostly right? which cv axles should I get, and I like spectrom (bad spelling I know)radios, which radio do I need to get or should I get
Old 01-08-2013, 09:36 PM   #10
Either vanquish steering knuckles will work great. You just need to get a radio that can supply a greater turning effect than stock( rtr) to take advantage of the knuckles. I highly suggest them . Also a longer travel steering arm. To take advantage of the full effects.
im gunna crawl is offline   Reply With Quote
Old 01-09-2013, 02:43 PM   #11
if you get the 8* knuckles you MUST get the 8* c-hubs to match. if you get standard inclination, you can use the plastic c-hubs if you want. as for radio, really depends on how much you want to spend ($50 or $500)
vanquish knuckles - Similar Threads
Vanquish Knuckles Wavekatcher Axial Wraith 3 09-18-2011 04:36 PM
Vanquish Knuckles paystin EnRoute Berg 9 05-11-2010 08:49 PM
