01-08-2013, 03:18 PM | #1 |
Quarry Creeper Join Date: Nov 2012 Location: Nampa
| MIP Driveshafts
Has Anyone have or had problems?? Or Opinions? Thoughts? on them |
01-08-2013, 03:23 PM | #2 |
| Re: MIP Driveshafts
As long as you loctite the grub screw, they are bulletproof. |
01-08-2013, 03:24 PM | #3 |
Quarry Creeper Join Date: Jan 2011 Location: Waterford MI
| Re: MIP Driveshafts
Never had a problem. I have them on all my rigs. Never broke one or bent one. There the best investment you will make on your rig.
01-08-2013, 03:32 PM | #4 |
| Re: MIP Driveshafts
ok thanks i bought them already just have not ran the truck still gettin a few more part for the truck
01-08-2013, 04:00 PM | #5 |
| Re: MIP Driveshafts
You won't be disappointed!
01-08-2013, 04:14 PM | #6 |
Rock Crawler Join Date: Jun 2010 Location: UTAH COUNTY
| Re: MIP Driveshafts |
01-08-2013, 09:26 PM | #7 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: MIP Driveshafts
Locktite the screws and get the driveline angle good ( the pinion to transmission angle should look like a real car or truck). There was a local guy who blew a front driveshaft apart , but it was from bad angles and too much power! With normal use they will last. I take mine out of my truck every 6 months and clean with brake cleaner and wd40. I then lube them with royal purple max film. And clean and lube the slip splines with Mobil 1 grease. Works for me.
01-09-2013, 02:36 PM | #8 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: MIP Driveshafts
only problem is that i took my time buying them |
01-09-2013, 02:51 PM | #9 |
| Re: MIP Driveshafts
Only drivelines worth buying period. Everyone "saving" a few bucks buying knock off garbage end up breaking them eventually anyway. I drive line an asshole and they are the last part I worry about. As stated, loctite the grub screws and they won't fail you. My basher ax10 runs a 3800kv 4 pole on 3s and I have zero driveline issues. Front shafts, well that's another story! |
01-09-2013, 05:02 PM | #10 |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: MIP Driveshafts
2 years and still running my first set , the only thing i did was rebuild them after 1.5 years and even then they were still fairly intact. you wont regret buying them. |
