01-13-2013, 05:03 PM | #1 |
Newbie Join Date: Jul 2012 Location: Roanoke
| Battery suggestions
I have a SCX10 Honcho and its basically stock, I'm still running a 7.2 volt battery but my run times are really short, my question is what battery's are y'all running and what are the run times,I was looking about getting an 8.4 volt and traxxas plugs because my cusion has that I'm his truck and it seems to to O.K, thanks
01-15-2013, 12:30 PM | #2 | |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
| Re: Battery suggestions Quote:
01-15-2013, 04:30 PM | #3 |
Quarry Creeper Join Date: Nov 2008 Location: NorCal
+2 for making the switch to LiPo... once you convert you will never go back |
01-15-2013, 05:09 PM | #4 |
Newbie Join Date: Jul 2009 Location: Westminster/Walhalla
Lipo all the way. Got a 2 and a half hour run time on a turnigy 5000MaH lipo this past weekend. Actually I had more battery left but I was done crawling.
01-15-2013, 05:14 PM | #5 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
lipo. i usually run longer then i have patience for when running a 5Ah lipo. go lipo and never look back. |
01-15-2013, 05:55 PM | #6 |
RCC Addict Join Date: Jul 2011 Location: Orlando
I would say 150% switch to LiPo. Get a castle BEC set at 6volts and you can run 3s LiPo all day with no issue. Just think of the mah rating like the size of a gas tank. 5000mah will run longer then 2200mah. 3s will give more power then 2s . Good luck. But once you go LiPo you will never want to run the old NiMh packs again. Sent from my Galaxy Tab 2 10.1 |
01-15-2013, 06:08 PM | #7 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
+1 on a bec and 3s! I get about 2+ hours on a 4000 mah 3s and like others have said once you go lipo you never go back! Same goes for the difference between 2s and 3s.
01-15-2013, 08:07 PM | #8 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
guess you could say, the higher volts, the higher octane fuel, the higher aH, the bigger the gas tank.
01-15-2013, 08:39 PM | #9 |
Pebble Pounder Join Date: Aug 2012 Location: bonney lake
I run 1300mah 3s it last me threw all the courses with plant to go.. like every one else says lipo is the shnit!!! What do you mainly do with the truck?
01-22-2013, 03:02 PM | #10 |
Well I usually run my truck,everywhere that has obstacles and dirt/mud, hill climbs, it's an all purpose trail truck. I guess I've got to look into a lipo.
Battery suggestions - Similar Threads | ||||
Battery suggestions | smoedog | Electronics | 4 | 12-19-2012 12:20 PM |
Battery suggestions for xr10 | dusty sweep | Electronics | 1 | 10-17-2010 06:32 PM |
battery suggestions | reblekid | Electronics | 0 | 02-12-2009 11:07 PM |
Battery Suggestions? | Mini | Newbie General | 6 | 12-30-2008 09:19 AM |
need battery suggestions | hardin316 | Newbie General | 2 | 12-16-2006 07:46 PM |
