Thread: Battery suggestions
Old 01-13-2013, 05:03 PM   #1
Default Battery suggestions
I have a SCX10 Honcho and its basically stock, I'm still running a 7.2 volt battery but my run times are really short, my question is what battery's are y'all running and what are the run times,I was looking about getting an 8.4 volt and traxxas plugs because my cusion has that I'm his truck and it seems to to O.K, thanks
318 wagon is offline   Reply With Quote
Old 01-15-2013, 12:30 PM   #2
Default Re: Battery suggestions
Unless you switch over to a lipo battery, you won't be able to get really long run times without running a massive battery. I am currently running a 2600mah 2S pack. It is lightweight and lasts me for around 1 1/2 hours.
BadRockNoCookie is offline   Reply With Quote
Old 01-15-2013, 04:30 PM   #3
+2 for making the switch to LiPo... once you convert you will never go back
BodiBuilt is offline   Reply With Quote
Old 01-15-2013, 05:09 PM   #4
Lipo all the way. Got a 2 and a half hour run time on a turnigy 5000MaH lipo this past weekend. Actually I had more battery left but I was done crawling.
Dingleberry is offline   Reply With Quote
Old 01-15-2013, 05:14 PM   #5
lipo. i usually run longer then i have patience for when running a 5Ah lipo.
go lipo and never look back.
Deerhurst is offline   Reply With Quote
Old 01-15-2013, 05:55 PM   #6
I would say 150% switch to LiPo. Get a castle BEC set at 6volts and you can run 3s LiPo all day with no issue.
Just think of the mah rating like the size of a gas tank. 5000mah will run longer then 2200mah. 3s will give more power then 2s . Good luck. But once you go LiPo you will never want to run the old NiMh packs again.
Sent from my Galaxy Tab 2 10.1
AsILayDying is offline   Reply With Quote
Old 01-15-2013, 06:08 PM   #7
+1 on a bec and 3s! I get about 2+ hours on a 4000 mah 3s and like others have said once you go lipo you never go back! Same goes for the difference between 2s and 3s.
CRAWLERJOE is offline   Reply With Quote
Old 01-15-2013, 08:07 PM   #8
guess you could say, the higher volts, the higher octane fuel, the higher aH, the bigger the gas tank.
mitchr97 is offline   Reply With Quote
Old 01-15-2013, 08:39 PM   #9
I run 1300mah 3s it last me threw all the courses with plant to go.. like every one else says lipo is the shnit!!! What do you mainly do with the truck?
BoostFreak is offline   Reply With Quote
Old 01-22-2013, 03:02 PM   #10
Well I usually run my truck,everywhere that has obstacles and dirt/mud, hill climbs, it's an all purpose trail truck. I guess I've got to look into a lipo.
Battery suggestions - Similar Threads
Battery suggestions smoedog Electronics 4 12-19-2012 12:20 PM
Battery suggestions for xr10 dusty sweep Electronics 1 10-17-2010 06:32 PM
battery suggestions reblekid Electronics 0 02-12-2009 11:07 PM
Battery Suggestions? Mini Newbie General 6 12-30-2008 09:19 AM
need battery suggestions hardin316 Newbie General 2 12-16-2006 07:46 PM
