01-29-2013, 07:35 PM | #1 |
Newbie Join Date: Jan 2013 Location: irvona
| mirror a scx10 transmission???
i just got a new scx10 trail honcho i wanted to know can i mirror the transmission and is it worth it and if i do it how do i get my motor to turn the right way
01-29-2013, 10:43 PM | #2 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
| Re: mirror a scx10 transmission???
Search. Itll probably pop up as one of the first results. Basically take it all apart and literally mirror it. Motor ends up pointed the same way on the other side of the tranny but it wont accept the gear cover. Dont even have to reverse the motor direction. |
01-29-2013, 10:57 PM | #3 |
Pebble Pounder Join Date: Oct 2011 Location: Murfreesboro
Or you could just flip your skid, lol.
01-30-2013, 08:29 AM | #4 |
ok so this isnt right is it i found a forum that told me how to do it step be step but by motor is on the back side of the truck now ????? this is the truck before i tryed to mirror it [IMG][/IMG] and this is now what did i do wrong or did i??? [IMG][/IMG] Last edited by tmaxxman80; 01-30-2013 at 08:33 AM. |
01-30-2013, 09:17 AM | #5 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
nope that is just flipping the skid which moves motor weight back. you want motor to stay in front of vehicle. I order to mirror the tranny, you must take it apart and put it back together the opposite way if that makes any sense to you. It sounds difficult but is not at all. flipping the skid does not help with torque twist like mirroring the tranny proper method is found here SCX10 Transmission Mirror/Flip! should look like this when done like this Last edited by discgolferlee; 01-30-2013 at 09:25 AM. |
01-30-2013, 06:54 PM | #6 |
Newbie Join Date: Sep 2011 Location: Youngstown
I used the site mentioned above to mirror mine and it helps a ton with torque twist, recommend it to anyone who hasnt yet
01-30-2013, 07:26 PM | #7 |
Rock Stacker Join Date: Jan 2013 Location: Ohio
Why didn't axial do this from the factory? I've yet to do it, but am curious.
05-04-2013, 11:41 PM | #8 |
Newbie Join Date: Apr 2013 Location: Aus
old thread first post blah blah i jut did this except i cant mount it back because the can hits the link screw now?
05-05-2013, 12:21 AM | #9 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
Flip the screw so it goes in from the inside with the nut on the outside.
05-05-2013, 08:50 AM | #10 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
i took the shorter screw from the side it was on and swapped them worked out great and love the fact that there is little torque twist now
mirror a scx10 transmission??? - Similar Threads | ||||
Mirror Imaged Transmission | EeePee | Axial AX-10 Scorpion | 174 | 11-27-2017 03:07 PM |
How to mirror a transmission? | Tourettic1 | Newbie General | 3 | 11-09-2012 08:41 PM |
Transmission Mirror help! | ieatfish | Axial SCX-10 | 2 | 03-17-2012 12:56 AM |
