Vp wraith links Dont know if anyone has tried this, but vp wraith links work on the new jk axial. Just put mine on tonite. Had them sitting next to my jk and wondered if they would work and sure enough they did. |
Hi, Thanks for the info!i put up my wraith kit links on my scx10. Just had to shorten the front ones a bit by putting shorter rod ends to it.http://img.tapatalk.com/d/13/02/04/3aha9a7u.jpg |
Re: Vp wraith links Quote:
Re: Vp wraith links Forgot to measure. Will post pics and info after work. "thumbsup" |
Re: Vp wraith links I did an aluminum link upgrade using all Axial parts from Wraith, XR10 and SCX10 for the links and rod ends http://www.rccrawler.com/forum/axial...rubicon-2.html see post #33 Wheelbase stays stock with that. Would be also interessted what the wheelbase would be with the VP Wrait links. Would guess that it is more. |
Re: Vp wraith links If the wraith VP links make the wheel base longer then the stock 313mm I'll get a set. I keep bending the crap out of the stock axial aluminum links. |
You guys might wanna check the chaotic crawlers high clearance links for the wraith. |
I havent tested it out yet since i gotta them off my wraith first. When i get the time i ll post some picture. You re probably right bout the standard links having a better fit |
