12-17-2012, 04:14 PM | #21 |
Quarry Creeper Join Date: Nov 2008 Location: The land of bagged milk
| Re: Rubi_con_Arni - Axial Jeep Wrangler Unlimited Rubicon
Thats a good looking rig!
12-17-2012, 05:43 PM | #22 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
thats a nice paint job! the winch is a rc upgrade winch. RC Upgrade Automatic Rock Crawler Winch w O ESC Fits F350 CC01 D90 D110 RC4WD | eBay |
12-18-2012, 03:47 AM | #23 | |
Quarry Creeper Join Date: Jan 2008 Location: San Pedro Alcantara-Spain
| Re: Rubi_con_Arni Quote:
RC Upgrade Automatic Rock Crawler Winch w O ESC Fits F350 CC01 D90 D110 RC4WD | eBay | |
12-18-2012, 06:21 AM | #24 |
Pebble Pounder Join Date: Jan 2012 Location: McPherson
| Re: Rubi_con_Arni AsiaTees has that same winch without the controller in silver and black. Miscellaneous All Aluminum Winch for 1/10 Rock Crawler Black TopCad 80118 |
12-19-2012, 02:46 AM | #25 |
Pebble Pounder Join Date: Aug 2007 Location: Switzerland
| Re: Rubi_con_Arni - Axial Jeep Wrangler Unlimited Rubicon |
12-19-2012, 02:53 AM | #26 |
Thanks a lot for the kind comments. It is motivating me to do more on my rig and to share my experiences with you. Thanks for the links to the other winches. There as some small differences such as the hook or the winch cable or motor cover but the seems to be basically the same. Nice prices especially I don't need the controllers. The Jeep is doing very well so far. We had a small challange last Saturday. Was able to take 2. place with my team buddy. Was a G6 but was a bit untypically as there was a lot of dissolving snow (hope that is the right espression) and it was hart to drive. Hope to test it more soon. Last edited by perseus71; 12-19-2012 at 02:56 AM. |
12-19-2012, 01:58 PM | #27 |
Rock Stacker Join Date: Feb 2011 Location: Los Angeles
This thing is sweet looking! I have the older Dingo kit, and really want the new Rubicon, so this might push me over the edge to get it. Sweet rig, man!
12-20-2012, 01:42 AM | #28 |
12-30-2012, 01:57 PM | #29 |
Newbie Join Date: Dec 2012 Location: Fuquay
Thats one awesome rigged out JEEP!!! The winch is crazy! I new years ago it would only be a matter of time before they started making that stuff!
01-01-2013, 07:12 PM | #30 |
Newbie Join Date: Jun 2012 Location: Honolulu
Hey awesome paint job! What color is that? Did you remove the original silver paint or paint on the outside?
01-06-2013, 03:20 AM | #31 |
Thanks a lot! I used Faskolor and mixed the gray myself. I painted the body from the outside. I do it always with silver at the inside and the body color from outside so when it get scrached it looks like the bar metal is comming out. So it is perfect Axial did paint the rtr silver. Regards Rene |
01-06-2013, 04:03 AM | #32 |
Quarry Creeper Join Date: Sep 2012 Location: Connecticut, USA
Awesome build man! I'm gearing up to overhaul mine. Still working out what to do about that awful interior. So far I just have a wrestler in mine cut in half. I picked up one of those terminators a few weeks ago as we'll as the robot version. I've got the T-800 driving my wraith right now.
01-07-2013, 04:34 AM | #33 | |
| Re: Rubi_con_Arni - Axial Jeep Wrangler Unlimited Rubicon Quote:
I have a plan to do a interor too but will probably wait till Axial brings out a clear one so I can work on that while still being able to drive the Jeep. Will place an driver when I have the interior done. | |
01-07-2013, 05:12 AM | #34 |
It's been a while since I last shared any upgrades so it's time to show you what I have done the last two weeks. First I have upgradet the links to aluminum links using parts from Wraith and XR10 I have left from other builds. Also the front upper from the 3-link setup are all aluminum, the links, the Y-piece and the upper link mount. I used one from 3Racing. Hope this will hold up better than the one from Hot Racing. I used following parts: Rear upper links: Lower links from the Wraith kit 7x87.5mm with long bend rodends from Wraith Rear lower links: 7m94mm links from XR10 with long bend rodends from Wraith Front lower links: Lower links from Wraith kit 7x87.5mm with long bend rodends from Wraith at one side and short bend rodends from XR10 at the other. Front upper links: Same parts as used with the old Honcho kit. Don't know the part numbers or the lenght but you can find them in the manual which you will find on Axials homepage. Here are some pics... |
01-07-2013, 05:21 AM | #35 |
While I was doing the links I also changed the hubs and knuckles to aluminum from Axial. Probably not nescessary but I like aluminum The srew of the servo horn was touching the chassis brace so I made a new servo plate out of a carbon plate and moved the servo 4mm back. |
01-07-2013, 05:32 AM | #36 |
This was the Christmas week. Last week I have made wheel houses. Without paint... |
01-07-2013, 05:36 AM | #37 |
... and with paint and the new shocks installed...
01-07-2013, 05:44 AM | #38 |
I will probably reduce the ride hight by an spacer in the shock bodies to limit travel as I was not so happy with the car performace at the test last Friday. I will go back on stock shocks to see the difference when driving at the same spot. I will also redo the paint job on the wheel houses as the paint does not stick on them even though I have used paint for plastic. Will try to give the wheel house a protective underbody look too. |
01-07-2013, 05:55 AM | #39 |
When I bought my Jeep I also got some Pitbull tires and RC4WD steelys. Unfortunately I was not able to mount the Pitbulls on the steelys as the rubber is very soft and the tire bed is popping off the wheels when I tighten the beadlock screws. So I wanted to take the Gear Head wheels of my Honcho already but then found some new wheels from Gear Head at RPP. A bit difficult to mount the Pitbulls on them to because of the soft rubber but it is possible and worth it I think. As the offset of these wheels is less than of the stock and the RC4WD wheels I will have to use the wider wheel hubs from Axial to avoid the tire from rubbing against my steering likage. Last edited by perseus71; 01-07-2013 at 05:58 AM. |
01-07-2013, 08:10 AM | #40 |
Rock Stacker Join Date: Aug 2005 Location: australia
This is a very cool rig. I really like the roof rack... where about did you get it if you don't mind me asking? Top job on the rig. . |
