Thread: Overdrive/under drive
Old 03-03-2013, 04:53 PM   #1
Default Overdrive/under drive
So I got a used dingo. Have been doing work here and there. Was looking into under drive overdrive gears. Been to axial website for what the stock gears are. Was wondering if I could do just front axle for better turning or if I need to address both ends? Thanks for the info.
rmiranda134 is offline   Reply With Quote
Old 03-03-2013, 04:59 PM   #2
Old guy
ROCKEDUP RICKY's Avatar
Default Re: Overdrive/under drive
You coud do just the front and it will help a little. Do both and it will help alot.
ROCKEDUP RICKY is offline   Reply With Quote
Old 03-03-2013, 05:22 PM   #3
This thread has info on over/under gearing and has information on the performance of the setup.
Optional Ratio Gear Sets
k7zpj is offline   Reply With Quote
Old 03-03-2013, 05:27 PM   #4
Ahhhhh. I knew I saw that somewhere a while back. Just couldn't find it again. Thanks guys
Old 03-03-2013, 05:31 PM   #5
Ordered both
Overdrive/under drive - Similar Threads
How much to overdrive? TurboShadow General Crawlers 2 05-31-2011 08:24 PM
Overdrive Under drive Questions Rockies26 Axial AX-10 Scorpion 8 03-01-2010 07:27 PM
AX10 MIP C Drive dig drive shafts in stock! RPP Hobby RPP Hobby 1 12-03-2009 10:50 PM
Overdrive? BJoe General Crawlers 0 10-31-2009 10:10 PM
