Thread: Removing Axial Ball Links
Old 03-31-2013, 08:44 AM   #1
Default Removing Axial Ball Links
Hi, does anyone have any tips or tricks on how to remove axial ball links from the jeep shocks? I don't want to break anything.
Thanks
JimmyPickles is offline   Reply With Quote
Old 03-31-2013, 09:25 AM   #2
Default Re: Removing Axial Ball Links
Standard size pliers, but if you replace them with the metal balls they might want to pop out of the links. Or you could buy a new parts tree with the links. You might have gotten enough extras in your extra parts bag (if you bought it new)?
im gunna crawl is offline   Reply With Quote
Old 03-31-2013, 09:30 AM   #3
On my axial wraith I removed and the plastics pivot balls and replaced them with traxxas ones. All I did was use pliers to pop them out and pop them back in. No troubles as our yet. And they survived about a fifteen foot tumble down a rock face in the abandoned quarry down the road.
KustomKreeper8606 is offline   Reply With Quote
Old 03-31-2013, 03:00 PM   #4
I use ball-link pliers to gently pry them out. The "forks" fit snug under the flanged end of the ball.
05Fronty4x is offline   Reply With Quote
Removing Axial Ball Links - Similar Threads
removing shocks / links from ball studs benny27 Losi Micro-Rock Crawler 1 01-22-2012 07:38 AM
Need some help with ball links wulfbait Tamiya Txt-1 and Juggernaut 4 02-12-2009 08:00 PM
Removing Green off Axial Links?? kizzo Paint and Body 40 05-02-2008 09:20 PM
