Thread: Need help with my Dingo build
Old 04-13-2012, 01:23 AM   #1
Default Need help with my Dingo build
Im ordering a dingo today and need some help.
1. Im going to order ARB T-rex 60 axles, what else do I need to install them properly? I couldnt find a clear answer with suggested parts
ARB Special Edition T-Rex 60 Front & Rear Plastic Complete Axle
2. I want a CMS, but unsure which one I need. The "3 link" is throwing me off a bit
Hand Brothers Off Road*-*Manufacturers*-*The Crawlers Store LLC
Is there anything else i should look into or be concerned about? Ive heard mixed reveiws about the t-rex axles, but I love the look of them.
Thanks for your time
driftin2crawlin is offline   Reply With Quote
Old 04-13-2012, 04:39 PM   #2
Default Re: Need help with my Dingo build
I got my axles used and they came with everything, but I still may be able to help. Looking at RC4WD's website, it looks like those axles come with
1x ARB Special Edition T-Rex 60 Plastic Front Axle
1x ARB Special Edition T-Rex 60 Plastic Rear Axle
4x 4 Link and Shock mounts
8x M3 Hardware
They come with the (qty 4) link and shock mounts because you need the shock mounts whether or not you do 4 link or leaf springs. If you want to do leafs you need
this Leaf Spring Mount for T-Rex Axle if you already have leafs,
or this Simple Leaf Spring Mount Kit for T-Rex 60 Axle if you don't.
In order to do 3 or 4 link all you need
are these T-Rex 60 Axle Servo Mounts
or this T-Rex 60 Axle 3 Link kit
I have that whole 3 link kit and to make it 4 link you take the 3 link post off and use the 2 holes that mount the post for each upper link. Not sure if this is correct or what RC4WD intended, but it worked for me. Here's mine
3 link front, 4 link rear. Hope this helps.
steele42 is offline   Reply With Quote
Old 04-14-2012, 12:15 AM   #3
Thank you for all the help! This definitely answered my questions, I appreciate it
Old 04-06-2013, 08:03 AM   #4
Sorry to resurrect an old thread, but I'm not sure about what I need for these axles. I'm doing a chassis mounted servo, so do I still need to servo mount for the other thing that comes with it? Also it says on post 2 all I need is the 3 link mount and the servo mount, what about the rear 4 link? Sorry if I'm being a nuisance, I'm just not sure.
Cheers, Hammer
Hammer! is offline   Reply With Quote
Old 04-06-2013, 08:06 AM   #5
Sorry forgot to add, could I do 3 link on front AND rear?
Old 04-06-2013, 08:10 AM   #6
Once again, sorry! XP ignore the post above me, I just figured it out. Sorry about the triple post as well.
Need help with my Dingo build - Similar Threads
Axial Dingo / JK Build Black Venom Axial SCX-10 97 01-20-2013 12:16 PM
Bronco2x84's DINGO TR Build Bronco2x84 Axial SCX-10 3 02-15-2012 02:58 PM
My Dingo build sort of. BillH Axial SCX-10 9 02-06-2012 06:46 PM
dingo kit build sheeno Axial SCX-10 21 02-05-2012 01:35 PM
Dingo Build up. mwscooters Axial SCX-10 27 10-12-2011 03:27 PM
