04-18-2013, 08:07 AM | #1 |
Pebble Pounder Join Date: Sep 2012 Location: Uk
| Moorin's hilux wroncho build
Hello everyone! This is my second build thread but this time this one will be completed. I was building an scx10 style rig from scratch which was in the 2.2 section but since I have sold the chassis and bought the remaining axial parts to build a modified honcho with a hilux cab. Well had to wait a while but finally got a few parts sorted and built up: Using standard scx10 axles with lockers and waiting on the four link kit to arrive before I can get it on all four wheels but will update as and when I can! Rate/hate Last edited by Moorin90; 08-01-2013 at 02:10 AM. |
04-19-2013, 05:29 PM | #2 |
Newbie Join Date: Apr 2013 Location: Hartford Area
| Re: Moorin's yota/honcho hybrid build
so jealous of that purple body!
04-20-2013, 12:42 AM | #3 |
04-20-2013, 12:45 AM | #4 |
Quarry Creeper Join Date: Feb 2013 Location: Coupeville, WA.
| Re: Moorin's yota/honcho hybrid build |
04-20-2013, 12:56 AM | #5 |
| Thanks! I am just trying to get it up and running looking quite "stock" since it's been nearly a year at looking at parts and then will start fabbing up a cage etc for it |
04-20-2013, 01:03 AM | #6 |
What color of purple is that your using or color code? I like it, but what i am planning for my rig is going to be a little darker I think.
04-20-2013, 01:10 AM | #7 |
Well I'm from the UK but its a ford paint: We have a colour called "Cadbury purple" (after the chocolate bars) which is a darker shade: And some shots of the body now it's polished, sealed and waxed Also forgot to mention every hole has been filled on it as I'll be mounting it using Velcro. |
04-20-2013, 06:00 AM | #8 |
Pebble Pounder Join Date: Oct 2007 Location: Ohio
Nice start waiting for the rest!
04-20-2013, 08:32 AM | #9 |
04-26-2013, 09:13 AM | #10 |
Well my axial link kit finally came through so once collected from the collection office I decided to build the chassis into a roller, don't know if the shock extension plates need to be removed as the ground clearance is amazing at the moment. Not much articulation at the moment but can back off the damping on the shock reservoirs |
07-27-2013, 03:54 AM | #11 |
Long time since the last update but I managed to get the truck put together and use it a few times Managed to get the honcho bed to work with the lux body but thinking of fabbing up my own at some point. Only used it in anger a handful of times and already hating the ground clearance with the flat irons causing me to get the diff hung up on all sorts of little rocks. I also decided I liked the look of wraith axles so a bit of ebaying later and my old axles are sold and new wraith axles are coming soon Also trying to sell my flat irons to buy some 2.2 rok lox as they look a little taller and just a more scale tyre IMO. Also fitted the hilux grill and lights so need some LEDs to complete the look, So this is the "bag of bits" I'm left with at the minute: Sent from my iPhone using Tapatalk 2 Last edited by Moorin90; 07-27-2013 at 03:57 AM. |
07-28-2013, 04:06 AM | #12 |
Quick update, I have now ordered: 2.2 rok lox tyres Wraith axles Wraith steel steering linkage Arb diff covers And a led lighting kit Going to get around to welding a cage together and a front stinger as I would like a winch at some point. Updates to follow when parcels arrive (hate waiting on international post). :( Sent from my iPhone using Tapatalk 2 |
07-30-2013, 06:16 AM | #13 |
Found (hopefully) a decent hydro steering setup which I am looking Into: Who would be interested? Solution for hydro steering Who would be interested? Solution for hydro steering Also got some parts that have arrived so once I have got up after been on nights ill take some pictures but lets just say I'm excited haha Sent from my iPhone using Tapatalk 2 |
07-30-2013, 07:11 AM | #14 |
Ordered two 10mm bore 35mm stroke cylinders and one 16mm bore 35mm stroke cylinder so I can have a play and see how powerful the setup is going to be. Sent from my iPhone using Tapatalk 2 |
07-30-2013, 10:20 AM | #15 |
| Bit of a difference Sent from my iPhone using Tapatalk 2 |
07-30-2013, 02:38 PM | #16 |
Newbie Join Date: Jul 2013 Location: Spacecoast
How did you manage to make the cage and cab work together? I'm curios as I have both and am considering trying this.
07-30-2013, 02:40 PM | #17 |
The cab at the top is slightly smaller then the cage but if you get it aligned properly all I did was still a hole either side on the back of the cab near the top and tie wrapped the cage to the back of the cab to hold it in position. As you can see I have smoothed all the body securing holes so unjust velcroed it to the front body masts and tie wrapped the bottom of the cage to the chassis. Hope that helps. Sent from my iPhone using Tapatalk 2 |
07-30-2013, 02:46 PM | #18 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
interested in seeing if the steering set up will work. subscribed
07-30-2013, 02:49 PM | #19 |
07-30-2013, 08:09 PM | #20 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I'm curious about the rear cab piece, did you just decide not to use it. I like the color.
Moorin's yota/honcho hybrid build - Similar Threads | ||||
Moorin's hilux truggy UK build | Moorin90 | 2.2 Scale Rigs | 44 | 10-23-2013 02:11 PM |
*** Hilux Honcho Hybrid *** | Wild Snapper | 1.9 Scale Rigs | 34 | 06-27-2013 06:30 PM |
Moorin's hilux truggy UK build | Moorin90 | 2.2 Scale Rigs | 0 | 10-10-2012 01:38 PM |
